12-17-2015, 12:35 PM
1989 25' Excella
Albemarle
, North Carolina
How to bypass batteries and go on shore power?
Want to remove my two batteries and go on strictly shore power. Can I tape up battery cable after removal of batteries?
12-17-2015, 12:53 PM
Mantua
, Ohio
I think if you do that all your twelve volt stuff will be running off the converter? Not the optimum deal.
12-17-2015, 01:06 PM
Just curious
Why do you want to remove the batteries?
12-17-2015, 01:15 PM
1955 22' Safari
Laredo
Why not?
When I got my Bambi II it had no battery. Ran fine on Univolt until I replaced it with a modern converter.
12-17-2015, 02:10 PM
Princeton
, New Jersey
The converter is not intended to be the main power source for the 12 system. The batteries are that main power source. The converter is a battery charger.
yes under light loads the converter will supply 12 volts but it is not intended to be the only source of 12 volt power.
Leave the batteries in. If you do not have a smart converter, one designed for constant use, get one you will be a happy camper.
2004 Excursion 4x4
12-17-2015, 02:27 PM
2015 30' Classic
Pleasanton
It's perfectly fine to disconnect the batteries and let your converter supply 12 V while connected to shore power. In fact, while I'm connected to shore power I always leave my Use/Store switch in the Store position so that the converter does not charge my batteries with its single stage charger.
Good practice says to remove the negative connections from the batteries first. It's safer in case you accidentally touch ground while removing the positive terminal.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
12-17-2015, 02:32 PM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
Yes, one can simply remove the batteries and tape, or otherwise protect, the positive cable from shorting to the frame.
The original converters charge the batteries and use them as regulators to some degree. Voltage supplied by the converter alone will move around some as load increases, if the batteries are not in the circuit.
However, I have switch the batteries on and off when on long term shore power to keep them from being over charged without issues.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
12-17-2015, 02:41 PM
2012 25' FB Eddie Bauer
Fairbanks
, Alaska
Are you planning to tow the trailer without the batteries in place? If so, I think I'd be a little concerned about the proper operation of the trailer brakes without a battery, especially in an emergency where the breakaway switch is triggered.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
12-17-2015, 03:41 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Yes to the above. You have to have a working battery while towing the trailer it that is a consideration. I worry about the voltage regulation so I keep a batteries connected in mine. I also worry about power failures and like having some battery backup.
Would like to hear more about this. I am a little afraid of frying something that is voltage sensitive due to the lack of regulation
12-17-2015, 06:54 PM
Naples
Modern switch mode power converters (like what you have in an Airstream) serve 2 functions:
• provide sufficient 12VDC (nominal) for the operational requirements of the DC loads of the RV; things like control voltage for appliances like A/C, control boards, furnace fan, igniter boards, lights, etc.
• they also provide power used to charge the batteries.
We all know how bad the Parallax units are for battery charging, but they actually make a pretty good power source for operational DC in an RV.
This is great IF you don't intend to use your trailer on the road. Once you hitch up, both RVIA specifications AND most if not all local laws require that any trailer that is heavy enough to require trailer brakes MUST have an operational battery with sufficient capacity to engage the trailer's braking system in the event of a disconnect (activation of the break-away switch).
lewster
12-18-2015, 06:07 AM
Mantua
, Ohio
I think there are self contained breakaway switches with their own power source,.
12-18-2015, 07:46 AM
Naples
Trailers that don't have internal battery systems USA a small tongue-mounted battery for break away operation of the trailer brakes.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
lewster
12-18-2015, 08:21 AM
Princeton
, New Jersey
That system would cost about the same as trailer mounted batteries and create a new maintenance problem that most likely would be forgotten.
Why are you considering removing the batteries, weight?
2004 Excursion 4x4
12-18-2015, 09:28 AM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
In summary:
If you don't plan to move the trailer, then taking out the batteries is fine. Despite some earlier comments to the contrary, the stock converter is perfectly capable of providing you with all the 12 volts power you will need when plugged in to shore power without any ill effects. However, DO NOT attempt to tow your trailer without a properly charged battery as you will not have trailer brakes and will not only be operating your set up illegally but will also have a lot of trouble controlling the rig on the road.
Also, unless you make some changes to the stock Airstream wiring, I suspect that your tongue jack will not operate without the battery as I believe that the jack is wired directly to the battery and not to the breaker panel which is powered by the converter when on shore power.
Bob Martel
WBCCI# 5766
12-18-2015, 10:47 AM
Taos
, New Mexico
for my trailer no battery no 12v power, it's part of the circuit
12-18-2015, 10:57 AM
2005 30' Classic
Burlington
, Ontario
It may vary with age and design of the trailer, I'm not sure,
But with our 2005, It can be done just fine - in fact If I recall correctly, my manual even states that you can power all the 12v stuff in the trailer from the converter without any battery in place.
You do need at least one battery in place though to move the trailer in order that the
breakaway switch could do its job.
You are correct though that if you have one or both batteries out, you should protect the bare 12v + connector(s) from accidentally grounding because they will be live from your converter/charger.
Being inherently lazy, I generally just stick the positive connector into a heavy rubber glove that I carry for trailer washing! Not the best but it works!
I also have quick disconnect knobs on my battery connectors. I installed them because we just have the original (Not smart!) charger in our trailer and I am afraid of cooking the batteries if it remains connected too long.
If we are going to be on shore power for more than just a couple of days I disconnect the batteries - and try not to forget to put them back on line when we are ready to move!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
12-18-2015, 02:45 PM
Mantua
, Ohio
Aren't the trailer brakes actuated by the tv? It just the breakaway switch that needs its own battery, either on the switch itself or the one in the trailer.
12-18-2015, 03:29 PM
Princeton
, New Jersey
Under normal operation, traveling down the road, the brakes are powered by the TV. However if the trailer separates from the TV while on the road the brake-away switch closes and supplies power to the brakes assuming there is a battery to draw that power from. Keep in mind that current will be 6,12, or 18 amps, depending on your axle count. That requires a good size battery, like those normally in the trailer.
Noone has yet said why the OPer wants to remove the batteries.
2004 Excursion 4x4
12-18-2015, 07:28 PM
Chelsea
, Michigan
I'm not so sure that you get enough amps via the umbilical cord to power the trailer brakes.
Bob Martel
WBCCI# 5766
12-18-2015, 07:53 PM
Princeton
, New Jersey
Your suspicion is correct but has nothing to do with the breakaway switch and the current that would flow to the brakes when the switch is closed.
They are 2 different systems. The current supplied to the brakes from the TV is limited by the length and size of the wiring, all to often undersized.
The current flowing to the brakes when the breakaway switch is closed is only slightly limited by the wiring in the trailer, but very close to the max. This system is designed to come as close as possible to locking the trailer brakes and thus stopping the trailer ASAP.
2004 Excursion 4x4
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Batteries Shore Power
willyd |
Batteries, Univolts, Converters & Inverters |
10 |
07-28-2021 10:44 PM |
HELP?! On Shore Power, but lights dim, and power fades
TGadaire |
4 |
11-24-2012 05:18 PM |
Should I physically disconnect batteries if on shore power for 30+ days?
foqus |
Electrical - Systems, Generators, Batteries & Solar |
23 |
11-21-2009 05:34 PM |
Using shore power w/o batteries 1989 Excella 1000
VABelson |
4 |
12-29-2007 09:58 PM |
Shore power and battery power problems
jfremstad |
5 |
05-03-2007 08:23 AM |
