Old 01-25-2016, 09:34 AM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by idroba View Post
So now we are going to let self appointed thread censors decide when a thread has had enough, or "correct" answers and tell us to "put a fork in it"?
No thread is finished unless the moderators lock it so no one else can post. Just yesterday— or maybe the day before; all my days run together— someone performed some Marie Laveau voodoo to zombify a formerly-dead thread from eleven years ago. That's some serious thread necromancy!
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-25-2016, 02:24 PM   #16
Images: 59
I don't agree with that method of operation.
Don't take yourself so seriously. It was meant as a compliment to the first two respondents, who posted excellent and complete responses to the original post. Nothing more.
markdoane is online now   Reply With Quote
Old 01-25-2016, 07:41 PM   #17
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by phann View Post
At some point in the near future I will upgrade the stock converter to a three stage model. Meanwhile, I know my current converter delivers about 13.7 volts to the batteries while on shore power, but how many amps are being delivered? Im hoping to estimate how many hours I can safely leave the battery disconnect in the "Use" position while on shore power, based on the batteries current state of discharge. Also, do the amps delivered to the battery via the converte differ according to what the shore power connection Im using (i.e.. 30, 50, 20)?
Thanks for any info in advance.
Converters are best understood as a constant-voltage supply. They will deliver a smaller and smaller current to the battery as the battery charges. Overcharging is typically not a problem except in hot weather, and even then the batteries will be fine if kept watered. The real advantage of 3-stage converters is that they charge the battery more quickly. With new but fully discharged batteries the charging current may reach 30 or 40 amps but willl taper off to around 1-2 amps over a 48 hour period.
30 amps vs 50 amps @ Rv parks ColoradoLady Electrical - Systems, Generators, Batteries & Solar 18 07-25-2015 07:59 AM
Going from 50 amps to 30 amps for a 23FB KWN306 Electrical - Systems, Generators, Batteries & Solar 1 01-28-2015 11:12 AM
1973 Airstream Land Yacht Sovereign -- Many Many Many Upgrades!!! eBay Watch Airstreams on eBay 0 06-18-2013 06:30 PM
15 Amps vs 30 Amps billida1 Electrical - Systems, Generators, Batteries & Solar 8 10-01-2010 08:37 AM
How many Amps??? Sundance Batteries, Univolts, Converters & Inverters 3 07-02-2007 11:32 PM
