Old 04-10-2016, 10:23 AM   #1
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
How many amps are going to my batteries?
My batteries were at 12.3v so I plugged my trailer - 2014 with stock converter - to a 20 amp circuit. The only draw is my converter charging the batteries at 13.7v.
I see only a 1 amp draw per attached photo. Shouldn't I see more? Does that mean I'm only getting 9-10 amps per hour into my batteries?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 04-10-2016, 10:47 AM   #2
2015 30' Classic
Pleasanton , California
Surgeguard doesn't make any claims to the accuracy of their shore power line current measurement. Since they only display current to the nearest amp, I would guess that the accuracy is no better than +/- 1 amp.
So you see 1 amp, but it could just as easily be suppling 2 amps. At 122 V, that could perhaps be as much as 17.8 A if we neglect the efficiency of the stock converter.
The stock converter won't charge your batteries as fast as a proper three stage battery charger. Since your converter simply applies a constant 13.7 V to the battery, the battery charge current will slowly decrease at the battery charges towards this target.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 04-10-2016, 12:40 PM   #3
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Thanks. So I guess I could need quite a few hours to fully charge. I thought it would be quicker.
How many amps going to batteries on shore power? phann Batteries, Univolts, Converters & Inverters 16 01-25-2016 07:41 PM
30 amps vs 50 amps @ Rv parks ColoradoLady Electrical - Systems, Generators, Batteries & Solar 18 07-25-2015 07:59 AM
Going from 50 amps to 30 amps for a 23FB KWN306 Electrical - Systems, Generators, Batteries & Solar 1 01-28-2015 11:12 AM
1973 Airstream Land Yacht Sovereign -- Many Many Many Upgrades!!! eBay Watch Airstreams on eBay 0 06-18-2013 06:30 PM
15 Amps vs 30 Amps billida1 Electrical - Systems, Generators, Batteries & Solar 8 10-01-2010 08:37 AM
