Old 04-15-2009, 03:04 PM   #1
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
How is your Inverter installed?
I'm considering installing a 600W Pure Sine Inverter in my 22' CCD to run small appliances while we're Boondocking. It has to be hard wired so, I'm curious how some of you have installed yours. Can I run off one of the 3 spare 20 Amp DC circuits available to me on the DC fuse block?
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 04-15-2009, 05:54 PM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Here is how I connected ours to the battery. It is very important to put the inverter as close to the batteries as you can to keep the 12v cables as short as you can.
http://www.airforums.com/forums/f449...tml#post677341
As for plugging in devices, we use a plug-in strip. I did not try to integrate the inverter into the main system as some do.
Old 04-15-2009, 06:09 PM   #3
Images: 59
If you want to get the full 600 watts, you will need to use all three 20a circuits. Tie them together and run #6 wire to the inverter.
New Solardome Installed TomW 1967 Overlander 29 04-17-2017 09:25 AM
F.F. Installed in Bathroom fr8tshaker Roof Vents, Skylights & Fans 2 09-10-2008 07:19 AM
Airstream Installed Inverter craftsman Batteries, Univolts, Converters & Inverters 6 11-17-2007 12:23 AM
New Plumbing Installed Buttercup Fresh Water Systems 4 06-29-2005 10:50 PM
Installed the A/C... Anon Furnaces, Heaters, Fireplaces & Air Conditioning 40 06-13-2005 07:46 AM
