Old 05-26-2012, 05:21 PM   #1
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
How I changed my Lifeline AGM batteries
Our 2007 23’ Safari came from the Airstream factory with two Lifeline GPL-24T Deep Cycle AGM (Absorbed Glass Mat) RV batteries. Earlier this month they were five and a half years old and were beginning to not adequately hold onto a charge over the typical 5 days of non-hook-up camping that we like to do. So it was time to change the batteries and I wanted to do it safely and correctly, especially since our trailer came with the Airstream factory installed solar charging system.
I found “Disconnecting the batteries” posting and “How to Change Batteries in an RV” article helpful, but not comprehensive enough for my needs. The following information is how I went about changing my batteries, which worked well for me, and is presented here in the spirit that it might be helpful to others, but note that it is not intended to tell you how to change your batteries.
1. I found a list of local Lifeline Battery Distributors and obtained two Lifeline GPL-24T AGM batteries.
2. I took close-up photos of my existing batteries and wiring configuration (which included wires from the solar charging system and the Super Jack) as originally set up by Airstream.
3. I made a diagram of the wiring connections (see below).
4. I gathered my tools (socket wrenches, screw driver, wire brush and petroleum jelly).
5. I attached a label to each wire and assigned it a number (starting with #1 for the first wire to be disconnected), which corresponded to the illustrated diagram.
6. I physically disconnected the 30-amp AC shore power cable.
7. I put the Battery Disconnect Switch to “Store” position (the red light went out).
8. I covered my solar panels with a bedspread (just as a further precaution).
9. I removed the ˝” hex nut and disconnected the wires that were connected to the negative terminals first, beginning with the top shiny black wire with blue rubber end (solar), then the thick red cable connecting the two negative terminals, and finally I could loosen the clamp and remove the large black negative cable. (As a further precaution, I put each wire end in a Ziploc bag.)
10. I then removed the 5/8” hex nut and disconnected the wires that were connected to the positive terminals.
11. I unscrewed the battery compartment clamp and lifted the batteries out.
12. I cleaned the battery tray and compartment.
13. I lowered the new batteries in place and secured them with the clamp.
14. After I cleaned the wire ends and applied a thin layer of petroleum jelly, I reattached the wires, starting with the thick red positive cable with clamp to the positive terminal. The wires were reconnected in the reverse order of their removal. (I referred back to my diagram and photos to make sure which wire went over or under the other to avoid a bulge of wires that could make compartment lid closing difficult.) The wires were secured by tightening the nuts and a thin layer of petroleum applied to the terminals.
15. I put the Battery Disconnect Switch to “Use” position (I heard a click and the red light came on).
16. I verified that I had power in the trailer by turning on the stereo.
17. I uncovered the solar panels and saw that they were providing power to the batteries as verified by the solar monitor.
18. I plugged in the 30-amp shore power cable and checked appliances, such as the microwave clock.
19. I returned the old batteries to the Lifeline distributor (which enabled me to originally purchase the batteries at a lower price).
20. I let the new batteries get fully charged on shore power for two days and then I disconnected shore power and ran a test for several days to make sure that the batteries were being properly recharged via the solar panels.
Name:	DSC_0102 Changing batteries diagram.jpg
ID:	159368   Click image for larger version
Name:	DSC_0093 Lifeline GPL-24T AGM batteries.jpg
SilverGate is offline   Reply With Quote
Old 05-26-2012, 05:47 PM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Very nicely done. Thank you. Bookmarked.
Old 05-26-2012, 06:07 PM   #3
SilverGate's Avatar
2007 23' Safari SE
Thanks REDNAX... It's my hope that the moderators will designate this post as a "Sticky" for this Batteries sub-forum so that this information can easily be found by Airforums members.
Old 05-26-2012, 09:31 PM   #4
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Thumbs up
Excellent work. I have a similar setup, and will changing out my AGM's soon. Thanks for detailing the project.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 05-26-2012, 10:30 PM   #5
SilverGate's Avatar
2007 23' Safari SE
Thanks for the feedback SilverRanger... Good Luck with your project!
-- Bill
Old 05-27-2012, 12:20 AM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Thanks, Bill... As you know, we will also be replacing our batteries soon and you have the same set-up and batteries we do...this is VERY helpful...thanks for your detailed account...we can always count on you to provide us with great detail of your processes on upgrades and modifications to your AS... It helps the rest of us follow suit.
Happy Trails!
TB & Greg and Abbey Schnauzer
#3954
Old 05-27-2012, 01:06 PM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Excellant post, I will be updating my single G24 to a pair of AGM G27s shortly and adding solar panels. With the addition of a new converter/charger I should be almost self contained for extended periods of boondocking. This will help me keep the wiring set up straight in my mind.
MICHAEL
Old 03-14-2016, 07:24 PM   #8
2008 23' Safari SE
Houston , Texas
Add to my library
Rocket53 is offline   Reply With Quote
