Old 08-09-2009, 03:27 PM   #1
1987 32' Excella
Purcellville , Virginia
Hot Battery?
Hey all,
I plugged in overnight to top off the batteries ( I'm trying to figure out why my jack isn't working) and went to check the voltage this morning. Both batteries read 12.6 volts, one is incredibly hot to the touch the other is not. Any ideas out there? Any help is appreciated.
Todd
tde318 is offline   Reply With Quote
Old 08-09-2009, 04:28 PM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Are the two batteries wired together? Did you disconnect the charge wire to the batteries and then measure each battery separately (without being wired to anything)?
What type of charger are you using?
Hot batteries usually indicates a short, meaning a dead cell in the battery.
www.nesa.org
Air No. 6427
Old 08-09-2009, 04:37 PM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Replace batteries all the time unless Delco batteries are used. I am not a rep.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 08-09-2009, 05:12 PM   #4
richinny's Avatar
2011 34' Classic
i'd guess when you test the batteries individually, you'll find one bad battery. they should be replaced in pairs.
Ricky
Old 08-09-2009, 05:20 PM   #5
1987 32' Excella
Jim,
Sorry, I should have been more specific. I'm charging the batteries through the converter, I'm not exactly sure what kind but it's relatively new. I did not disconnect them before measuring, but I'll do that next. The hot one was actually 12.6 volts and the other 12.66.
Perhaps a short in the battery would be the cause of my jack acting up?
Todd
Old 08-09-2009, 05:59 PM   #6
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Check the jack fuse. It could be blown and have nothing to do with the battery. On our trailer, the jack is wired directly from one of the batteries. Check that too.
Gene
Old 08-09-2009, 06:33 PM   #7
1987 32' Excella
Thanks for the replies. I'm guessing I'll find the hot one is bad, and I'll replace both, and maybe with Delcos.
Gene,
This should probably be posted elsewhere but speaking of the jack; the fuse is good, it is pigtailed with the hot for the break-away and the wiring appears to be intact (no obvious rubbing on the frame or propane cover). Could one bad battery cause it to work intermittently?
Thanks again to everyone, this site is indispensable.
Todd
Old 08-09-2009, 08:24 PM   #8
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Yes and no.
The jack is a fairly high amp draw but the batteries at 12.6 should run the jack even if one battery is going bad.
If one of the batteries has a close to a dead short internally then "yes" it could stop the jack from working.
However; a short of this magnitude would draw the good battery down fairly quickly when not plugged in to shore power.
What I would look for 1st is a corroded connection at the battery terminals. Corrosion acts like a resistor and will not allow enough current (amps) get to the jack. They will also cause heat since it is a waste of power when charging or trying to use the jack.
Garry
univolt and battery hot mstblove Batteries, Univolts, Converters & Inverters 8 07-27-2009 11:19 AM
hot battery mlmarch Electrical - Systems, Generators, Batteries & Solar 3 11-18-2005 07:33 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
