Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 11-01-2006, 06:59 PM   #1
Mom scared by aluminum
dmaiden's Avatar
Profile:  1963 22' Flying Cloud
Tempe , Arizona
HF Battery Charger
Just wondering if anyone had ever used something like this for a charge controller? Obvious advantages are its cheaper and can be pulled out to be used at home. Don't know about the quality.
http://www.harborfreight.com/cpi/cta...emnumber=93996
Dave and Joanne
1963 Flying Cloud
2005 Silverado 4x4 3/4 Ton
dmaiden is offline   Reply With Quote
Old 11-01-2006, 08:07 PM   #2
Sugarfoot's Avatar
Profile:  1960 24' Tradewind
1956 30' Sovereign of the Road
Southeastern Area , Tennessee
I'm using a CTEK MULTI US 3300 on my Tradewind. I've been very pleased and it does fine for the simple set-up I have. As far as quality, I have no issues. Porsche, Mercedes, and Harley Davidson recommend them. Got it for around $69, it's a small lightweight thing, and I can quick connect to a pigtail on the trailer battery or use the clamps for charging whatever. My model doesn't have engine start capability. It's a Swedish product and on the European brochure the XS 3600 compares to the US 3300.
CTEK datasheet.pdf
TRAVELING WITH ELVIS
LIFE WITH A 1956 SOVEREIGN OF THE ROAD
• • • Aluminocentricity • • •
WBCCI# 14674, Washington DC Unit
Sugarfoot is offline   Reply With Quote
Old 11-02-2006, 09:13 AM   #3
just jd.
5cats's Avatar
Profile:  2007 20' Safari SE
San Diego , California
Originally Posted by Sugarfoot
I'm using a CTEK MULTI US 3300 on my Tradewind.[*snip*]
From the brochure, that 7000 model looks pretty nice. I'm adding CTEK to my list of widgets to investigate -- thanks!
dmaiden, that HF charger looks a bit high-amperage to me. I'd have to keep an eye out to avoid baking my batteries at 10A and higher, and 2A also seems high for a maintenance mode.
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 // xxxx
5cats is offline   Reply With Quote
Old 11-02-2006, 09:53 AM   #4
dmaiden's Avatar
Tempe , Arizona
thanks JD. amps and watts are Greek to me.
Dave and Joanne
1963 Flying Cloud
Old 11-02-2006, 10:35 AM   #5
Profile:  1975 29' Ambassador
Reno , Nevada
"Charge controller" is usually used in the context of DC to DC as in solar panel to battery. I am also confused by the "HF" designation. what does that mean?
Vector makes good battery chargers. Wal Mart sells them, too.
Your batteries can handle 20 amps of charging for every 100 amp hours of battery. For most modern Airstreams with two batteries that means you will get fastest charging with a 40 amp charger. Forget the linked ad claim of 2 hours to a full charge as that won't happen even with a properly sized battery charger.
While this battery charger does boast a float for maintenance, that is not its forte. And it is maintenance during storage that is a big deal for most RV's. You best bet for this would be something like the Batttery Minder, Here's some links:
Which Battery Charger is right for you?
Battery Testing and Charging
Battery Information
Car and Deep Cycle Battery FAQ, Battery Manufacturers and Brand Names List, and Battery References and Information Links List
ecoZen Battery Dictionary
Battery Minder, BatteryMinder Battery Chargers $39.90
Old 11-02-2006, 10:38 AM   #6
Profile:  , Minnesota
Images: 59
-jd.
I think these chargers operate 3-stages, similar to the Progressive Dynamics Intellipower. They have a bulk phase, absorption phase, and trickle/float phase. The difference is they have three different flows, so if you set it for 10A, it will drop to a lower flow during the absorption and trickle phase to prevent baking the batteries.
I don't think I would use one in place of a converter though.
Old 11-02-2006, 11:02 AM   #7
HHP
HHP's Avatar
Profile:  2006 23' Safari SE
Yucca Valley , California
I went with this Power Tender Plus.
"Power Tender Plus WATERPROOF, Shock & Vibration Resistant, Lightweight (LESS THAN 4 POUNDS), compact charger designed for either portable operation or permanent mounting. Charges and maintains both flooded and sealed, maintenance free, AGM, lead acid batteries. Float / Maintenance function maintains batteries at proper storage voltage without the damaging effects caused by trickled chargers. The Power Tender PLUS is easy to use, it’s rugged, its compact, it's packed with power, and it’s backed by the reputation of the undisputed battery charger industry leader, DELTRAN."
http://batterytender.com/default.php...0c3d34d53b743d
HHP is offline   Reply With Quote
Old 11-02-2006, 11:26 AM   #8
dmaiden's Avatar
Tempe , Arizona
Bryan,
HF is for Harbor Freight
Dave and Joanne
1963 Flying Cloud
Old 11-02-2006, 12:58 PM   #9
Reno , Nevada
" HF is for Harbor Freight" - thanks - shoulda' known that. I guess I got confused with ham radio (high frequency battery charger?) on my mind.
Old 11-02-2006, 04:18 PM   #10
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Profile:  1995 28' Excella
Artist , at Large
Images: 65
Hi,
I've owned and used this charger over the past year on my TV/ MC as well as friends batteries.
I've been very happy with it.
I found mine at Sams Club.
Michael
Click here Airstream Posters & Tee's
by Micheal Joseph Depraida
WBCCI No 8892 | VAC | KC2TQU
ArtStream is offline   Reply With Quote
Old 11-03-2006, 12:33 PM   #11
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Another model
Here's another by HF that seems to address some of the concerns of members here. You electrical types, what do you think?
http://www.northerntool.com/webapp/w...@sbcglobal.net
Fyrzowt is offline   Reply With Quote
Best battery charger for the money? Andy R Electrical - Systems, Generators, Batteries & Solar 27 10-01-2007 08:46 PM
battery charger ALANSD Batteries, Univolts, Converters & Inverters 8 09-16-2007 06:52 PM
Battery Location uwe 1970-79 Tradewind 22 09-04-2003 08:44 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 02:51 PM
