Old 08-19-2008, 10:57 AM   #1
Help with Troubleshooting Univolt
I have a 72 Tradewind that I suspect had a Univolt failure last night.
I was running a heavy load, including microwave, plug-in heater, tv and vcr
when I reached up to crank on the overhead fan....blackout...(except for battery power)
Anytime I've caused an overload before it has been a popped breaker on my trailer pad, hookup.
Not this time.... source is still hot.
I opened the Univolt door and the end plate with the knob and all fuses look good.
What probably happened?
What is best replacement unit, if needed.......?
Thanks for any of your short and longwinded answers... I welcome them ALL!!!
Thanks, John
yochanan is offline   Reply With Quote
Old 08-19-2008, 11:01 AM   #2
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Sounds like you tripped a 120 Volt breaker inside the trailer. Do you know where you 120 Volt (AC) breakers/fuses are located?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 08-19-2008, 11:06 AM   #3
Thanks, John
John.
Your microwave, TV, electric heater and VCR, have nothing to do with your "univolt."
Those are strickly 120 VAC appliances.
Fuses that "look good" can be bad.
Using a voltmeter, check the input to a fuse clip, and the output of a fuse clip.
DO NOT, check just the fuse.
When you check the fuse clips, you are also checking the connection between the fuse, "and" the clip.
Post back what you found out with that test.
Also please check your 120 VAC, circuit breakers, carefully.
Old 08-19-2008, 11:11 AM   #4
Thanks....."Breaker"....????
No, if the 72 had a breaker,...I don't know where it is but will start a search......
Old 08-19-2008, 11:17 AM   #5
The breaker panel, should be in a rear closet.
Old 08-19-2008, 01:17 PM   #6
Tradewind Breakers
Thanks Andy:
Center breaker was popped....Life is good again....ahhhh
John
Old 08-19-2008, 03:10 PM   #7
Thanks Andy:
John
Ah yes, life is so much simpler, in the "slow" lane.
electrical, tradewind, troubleshooting, univolt
Water Heater Troubleshooting charlie g Water Heaters, Filters & Pumps 10 10-03-2009 07:09 AM
Generator troubleshooting GlenCoombe Mechanics Corner - Engines, Transmission & More... 37 08-10-2007 08:37 PM
Troubleshooting a short davida General Appliance Topics 33 03-19-2007 08:59 PM
Troubleshooting power A/C pilgrim_still Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-28-2003 07:50 PM
onan troubleshooting help rcaldwel Generators & Solar Power 2 03-10-2003 05:00 PM
