Old 06-15-2007, 08:42 PM   #15
RiskIt's Avatar
1972 25' Tradewind
Lake Worth , Florida
Send a message via AIM to RiskIt Send a message via Yahoo to RiskIt
I do (I'm pretty sure) have them isolated and I do have a "blue sea" switch. The (2) 6's are connected in series.
Why "I'm pretty sure" is how I have the intelli connected to the bat's. I have the 6's in series to the switch then the 12 to the switch.... That should make them ISOLATED. I forget how I connected the intelli to the system. I'll have to look tomorrow in the light. I've been out a couple of times tonight and the "cheep-o" charger has put a charge (that keeps) to ALL bat's... SO I guess they arn't Isolated as I thought.
How should the Intelli be conected to a system like this???? Where in line?? Direct to the bat's or some other way?
Now we are getting someplace,thanks
RiskIt is offline   Reply With Quote
Old 06-15-2007, 10:47 PM   #16
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, on completely dead, or close to it, batteries you want to charge for 24 hrs at 2 amps or less. Dead batterries resist a fast / high amp charge; And dead batteries can and will burn out fast chargers and alternators.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-16-2007, 07:48 PM   #17
RiskIt's Avatar
1972 25' Tradewind
So I had time to look into the bat's today. Turns out the neg. ground had blown. How many times you read that here..... Easy fix. Replaced fuse and power up scotty.
I still wonder why when I charged the 12v the 6's where charging as well. I have them isolated. The only place they could connect is at the intellipower. The intelli has 2 pos out-puts and 2neg.'s and I have a set going to the 12v and the other to the 6's. I guess that how????
Should everything be fine with the bat's now that they are getting charged. Thats why you use a deep cycle bat. in the first place - right. I know there's only so many times you can recharge them and its never a good idea to run them dead... but sh#t happens. Somplace I read something on how to test your run time so you know how long you can boondock.
Anyone know what causes the neg. ground to blow?? (most com. reason??)
Thanks all
Old 06-16-2007, 11:52 PM   #18
Salem , Oregon
Images: 18
possible answer
Hi, "Anyone know what causes the neg. ground to blow?" [most com. reason??] Not sure with your system, but on cars, a fuseable link blows if you connect a jumper or charger backwards.
2005 Safari 25-B
Old 06-17-2007, 07:18 AM   #19
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Positive battery lead or wire touching ground will cause the fuse to blow.
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-01-2002 11:03 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
dead bolt joel Doors & Locks 1 08-25-2002 08:35 PM
help dead short pk63 Batteries, Univolts, Converters & Inverters 6 05-29-2002 08:56 AM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
