Old 06-20-2017, 07:21 PM   #1
Richmond , Texas
Question Help trip gfci breaker
All has anyone ever had an issue with the ground fault breaker? I have a 2016 FC30 bunk. Circuit 6 is a gfci breaker and is tripping occasionally three or four times a day and the converter is on this curcuit. I noticed that the fan on the converted is not running and the light on the battery disconnect never goes off in either store or use position. Nothing else is running on that curcuit except for the refrigerator. Any thoughts?
JamesSDancer is offline   Reply With Quote
Old 06-20-2017, 07:53 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If the breaker is repeatedly tripping, you need to get the situation looked into. The setup in the AS is close enough to residential wiring that a local electrician is the guy to see.
Old 06-20-2017, 08:27 PM   #3
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Verify if the outside outlet is on the same circuit many times the receptacle gets moisture in it.
I have had to dry mine out with blow-drier set on low.
Garry
Old 06-21-2017, 10:41 AM   #4
Half a Rivet Short
Hi
Silicone based spray lube is a good idea on the outside outlets. Do it with the power off ...
Old 06-21-2017, 12:16 PM   #5
John Geisen's Avatar
2005 28' International CCD
Palm Beach Gardens , Florida
Seems as though your fan should definitely be running. My "store/use" light stays on when I'm plugged into shore power. -John
John Geisen is offline   Reply With Quote
Breaker, Breaker!! Bing-Bing Generators & Solar Power 25 09-24-2013 09:25 PM
Replace 15amp GFCI breaker with 20amp? KYAirstream Electrical - Systems, Generators, Batteries & Solar 6 11-23-2012 09:20 AM
breaker breaker project66 Batteries, Univolts, Converters & Inverters 4 05-29-2012 09:37 PM
GFCI breaker Dusty-B Electrical - Systems, Generators, Batteries & Solar 13 03-18-2012 03:52 PM
GFCI in Campgrounds Always Trip Howard Lefkowitz General Motorhome Topics 3 07-12-2009 08:10 AM
