Old 03-27-2011, 05:53 PM   #15
1982 27' Excella
Mazomanie , Wisconsin
My univolt is much newer (1982) but the black wire in question supplies a "univolt on" indicator light. Perhaps you have such an indicator that is currently dark? Jeff
jbib is offline   Reply With Quote
Old 03-27-2011, 06:45 PM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Be Careful
I would not cut the wires and just connect them the way you think they should be. You need to make sure what each wire is designated to do. Otherwise you could damage the wiring, not to mention the devices connected to them. If you damage wiring behind the interior skin of the trailer you will have major problems.
I agree with wasagachris on the size of the black wire; it should be at least a #10 and preferably #8 because of the length.
Old 03-27-2011, 07:22 PM   #17
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Got ya - won't connect anything until I see what they do. Will open up the univolt tomorrow to determine what each wire is connected to. Thanks,
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 03-27-2011, 10:04 PM   #18
richinny's Avatar
2011 34' Classic
if jbib has it right you might find the answer here:
http://www.airforums.com/forums/f449...ing-65867.html
Ricky
Old 03-27-2011, 10:06 PM   #19
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Tim
Since the black wire in the garden hose is connected to the same terminal as the red wire, I would think that it is 12 volt and would also be connected to the same terminal (positive) on the univolt.
Here is the wiring diagram out of my 1966 owners manual for a 22ft. I can't see where it helps any, but it may help somebody else to chime in to help you solve your problem.
Dan
Old 03-28-2011, 06:27 AM   #20
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Dan, Thanks for your input. The garden hose black wire goes all the way out to the 7 way in the front of the trailer. It is not the same black wire that comes from the univolt. As soon as it warms up at bit (only 8 degrees now) I will open it up to try to determine what the black wire is.
Tim
TAC MI 14
Old 03-28-2011, 10:59 AM   #21
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
i have a 64, and the only black wire I had was up to the battery checker, and it was a much smaller wire. To me it looked like they oversized just about every wire. The stranded wires were almost all #10, and the 2 sets of solid wire looks like they were run to my lights where I had both 12v and 110 running to most of my lights. I basically just hooked all white to neutral and then mapped each of the colors to something in the trailer. Flipped on switches one by one to find out what they went to.
robwok is offline   Reply With Quote
Old 03-28-2011, 01:19 PM   #22
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I just discovered that the extra black wire from my univolt goes to the battery checker. I'm pretty sure I understand how things get attached. I will post again after I get it done. Thanks to all for the help.
Tim
TAC MI 14
Old 03-28-2011, 01:26 PM   #23
Ottawa , ON
Later Univolts also have a couple of wires on them that provide a shunt, and can be used to read the battery, and the tank gauges.
It's worth taking that stuff off your Univolt, if it's still there.
I don't think this applies to the '60s models, though...
Old 03-29-2011, 12:52 PM   #24
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I did get it in. Thanks to all that posted info. The hardest part was getting the old one out. I installed a 110 box for the PD 6245 to plug into and then the rest was very easy. All the reds and blues went to positive and the whites along with the phantom black went to negative. Check out before and after pics.
ID:	125692   Click image for larger version
Tim
TAC MI 14
Old 03-29-2011, 01:33 PM   #25
Ottawa , ON
Looking good!
What did you fasten the new voltage converter to? Did you build a little base for it, or...?
Old 03-29-2011, 01:44 PM   #26
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I screwed it to the floor just like the old one.
Tim
TAC MI 14
Old 03-29-2011, 01:48 PM   #27
Ottawa , ON
Ahhh, great idea!
Replacing Auto-Lamp 575- what's this second bulb for? Globie64 Electrical - Systems, Generators, Batteries & Solar 2 07-21-2011 09:17 AM
1960 wall wires blue black red white Lothlorian Lights - Interior & Exterior 2 04-02-2011 02:03 PM
Which wires are these? godaddy64 Electrical - Systems, Generators, Batteries & Solar 9 03-10-2011 12:00 PM
Replacing univolt questions Bmtt Batteries, Univolts, Converters & Inverters 2 02-24-2011 11:48 AM
Replacing the original 1970 univolt charger with a new Intellipower 9200-series ranger_rick Batteries, Univolts, Converters & Inverters 5 02-08-2011 07:23 PM
