Old 01-16-2012, 11:04 AM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Can you post a pic of the other side of the board? I see what looks like a pin out for a double pole double throw switch on the back of the board.
When you say the white wire is a short. How are you measuring it? Usually white wires in a trailer are ground/common. The brown wire looks like it should be the +12 volts since it is connected to the center pole of what I think is the switch. Do you read 12 volts between the brown and white wires on the connector?
Old 01-16-2012, 11:17 AM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The normal color coding on wires is black = hot, white = common (the other side of the circuit), green or bare = ground. Red is used for a second hot wire in some applications. Brown can be anything.
The colors there may mean black and red are hot in and out; white and brown could be common in and out. All maybes. Brown could be ground and green common. Trace the harness back to where it starts if you can, or locate the other end of it and see where the wires go and that may tell you what is what.
Auto wiring tends not to always follow the color coding that is required in 120 v. wiring, thereby making everyone a little more crazy.
What was hot and what was not?
A short in the white? Take a long piece of wire and connect (jump) at each end of the white and see if things work. If that works, then clip off the bad white wire, connect the new wire at one end and thread it through cabinets and such until you get to the other end. When the new wire goes through holes and past sharp objects, protect it with rubber grommets or lots of good electrical tape.
You could trace the wires through the board and see what is attached to what side of the switch. There are one or two black things on the left side of the circuit board that look like dip switches (switches that slide back and forth). If so, they must do something. Is there any way they could have been pushed the wrong way? There may be a capacitor to the light—that would probably keep it on for a while when the switch is turned off.
The battery disconnect switch confuses most of us. Turn it off and the light stays on, but supposedly will go out after you turn on something using 12 v. So it seems when giving it cursory look, the light means nothing. It looks like no matter which way you press it the light stays on, but maybe will go out after a while. I have seen transformers for some devices with a light that stays on for a while after unplugged. I believe I have read the propane detector, though 12 v., stays powered even if the batteries are disconnected (could one or more wires from the switch go to the propane detector?). So it is the battery selective disconnect switch.
Gene
Old 01-16-2012, 03:23 PM   #17
elfirebob's Avatar
2007 25' International CCD FB
1970 23' Safari
1956 16' Bubble
Jamul , California
Images: 159
Connections and bypass under your bed.
KerriO,
All your tests, connections and bypass wires should be under your bed up front.
As pointed out, all leads are focusing on your 12v switch and that same bundle of wires at the switch are also at the solenoid switch that isolates your batteries to your coach.
Start at your batteries where they enter the coach, under your bed. This is where your solar hooks into the system, where the power comes out to the intrior of the coach via the 12v isolator switch. The same five wire bundle you have at the switch near your rear entry door comes out under your bed. Test here to see if it's the switch button or the contact battery switch itself, or just connections.
Remember that testing with bypass wires are ok for a short time during trouble shooting, fix with proper wire size and components.
If you are in the SoCal area, RV supply and AS dealers are fairly close.
Good luck, and ditto on the electrical knowledge, 12v and 110v , add some solar and an inverter, gotta be fun. I have the same componets in our rig.
Stream Safe,
Bob U-
San Diego, CA.
The " TinDen "
2007 25' International FB
1970 Safari 23' Land Yacht
1956 Bubble 16' California Whale Tail
Charter Member 4 Corners Unit
(View all of elfirebob's images)
elfirebob is offline   Reply With Quote
Old 01-16-2012, 03:26 PM   #18
KerriO's Avatar
2008 27' International CCD FB
Bay Area , California
Thanks all, we are at SW Coaches near Los Angeles right now, as this job seems to be bigger than us. Guy is looking at it right now, and says there's no power to the solenoid, and that some fuse is really hot to the touch when it shouldn't be. I'll keep you posted.
To further make things difficult, our batteries are located in the rear storage compartment, and the storage door doesn't open all the way because of our PP hitch, so he guy has to take the bed platform off to access the battery area and all if its various stuff.
[[ Captain's Log ]] Our full-time journey in our 27'FB International
KerriO is offline   Reply With Quote
Old 01-16-2012, 05:30 PM   #19
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Glad you ended up at an RV place to resolve the situation. Good move. When I saw your picture of the backside/guts of the switch plate I said to myself, "Yikes! That's more than a "switch"!" There are some simple switches in an Airstream, but that is definitely not one of them!
I have a rule: I can only do and can only know so much ... and when I get to the end of my ability, it is time to call in bigger guns ... lest I make it a "worser situation." It works for me every time!
Hope it gets fixed up for you soon and you can be on your way...
TB & Greg and Abbey Schnauzer
#3954
Old 01-16-2012, 10:35 PM   #20
KerriO's Avatar
TB, so true. And turns out that it was it was not even as simple as a complicated switch. There were two wires that ran near or under the water heater where the insulation had been worn away and the wires were arcing at some point ( scorch marks even). We're in a hotel tonight because they have to continue work tomorrow to tear up the trailer to reach the wired that need repair. Yikes. I'm glad no further damage was done. And the cost of the repair is relatively low considering.
Old 01-17-2012, 01:33 AM   #21
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Glad to hear you are getting the problem fixed and you'll be back on the road soon... At least you know all about that switch now!
#3954
Old 01-17-2012, 09:49 AM   #22
Master of Universe
Gene's Avatar
Now we'll ask you about it when we ours screws up.
Gene
12v
Oh No, Marathon issue! Bruce B Tires 158 11-08-2013 02:37 PM
Need help with surround sound when playing dvd/video hellsbay Electronics & Connectivity 11 05-28-2012 06:37 PM
05 Airstream CLASSIC 25 RV Travel Trailer Silver Bullet Luxury Camper New Tires S05 A eBay Watch Airstreams on eBay 0 04-05-2012 12:50 PM
Most popular trailer size danlehosky Airstream Lifestyle 67 04-05-2012 06:32 AM
2012 airstream 19 bambi international series travel trailer camper big sale call eBay Watch Airstreams on eBay 0 04-04-2012 07:50 PM
