Old 06-10-2009, 07:35 AM   #1
trevisgardne's Avatar
1973 31' Sovereign
Maryville , Tennessee
Help-Group 31S vs Group 27 Battery Question
Help. I am in a bit of a unique situation. I need a new battery immediately for my 73 Sovereign. I know that it has a Group 27 battery in it. I do not have immediate access to my Airstream to measure the battery box. My vendor has a Group 31S in stock that is discounted.
Can anyone tell me if it ( the Group 31S) will fit?
T
trevisgardne is offline   Reply With Quote
Old 06-10-2009, 08:07 AM   #2
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
Can't tell you about the Group 31S, but a Group 29 fit in my '72 Sovereign--which should have the same sized battery box as your '73. The specs on the Group 29 vs. the 27 were minimally better but probably not enough to make an appreciable difference. Going with a larger battery can make it more difficult to find room for the battery cables. If you've still got the original cables, they are pretty stiff and get hard to stuff in there and close the compartment. Just food for thought....Good luck!
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 06-10-2009, 08:20 AM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I couldn't get a 31 to fit the battery compartment of our Sovereign. It is longer and taller than a 27.It MIGHT fit if you got a 31 with screw-on posts, rather than the big lead posts.
Old 06-10-2009, 08:29 AM   #4
Mexray's Avatar
1978 28' Ambassador
Morada , California
We have the fwd battery boxes in our 78 Ambassador, and the Group 31's won't fit in those compartments...
I'm in the Battery biz, and the 13 inch length (vs the 12 in of the Gr-27's) is just to long...the trays inside the box fit the Gr-27's just perfectly...
BTW: most good, flooded cell deep cycle, G-27's are rated at about 105 Amp Hr, while the deep cycle G-31's can be rated up to 140 Amp Hrs...
The group 29 is also a 13 inch long battery, usually rated less than the G-31 sizes...
I wanted more total Amp Hrs, so I mounted a third group 27 battery in a box on the tongue, behind the propane tanks...I used the same size battery as my other two, so when they are all hooked in 'parallel', the cell sizes will be the same for equal charging/discharging...
Ray & Pat; Morada, CA
Old 06-10-2009, 08:32 AM   #5
Mexray's Avatar
1978 28' Ambassador
Morada , California
Some pic'sClick image for larger version
Name:	qb side [Desktop Resolution].JPG
Name:	AS Battbox 2.JPG
New to the group -1965 65trotter 1965 - 1969 Globetrotter 29 11-16-2008 12:34 AM
Hello Group Heirstreamer Member Introductions 4 01-22-2007 05:55 PM
New to the group alhoos3228 Member Introductions 1 06-15-2006 12:28 PM
Bambi upgrade to group 31 battery? rfield54 Electrical - Systems, Generators, Batteries & Solar 0 05-17-2005 09:33 AM
Battery Group BA Sovereign 1974 - 1979 Sovereign 4 09-16-2003 10:28 PM
