Old 03-29-2010, 08:01 AM   #1
MTsafari's Avatar
1970 23' Safari
Columbia Falls , Montana
Help for the Inverter Challenged!
I've searched and read through most posts about installing an inverter; however, it reads like a foreighn language to this electrically-challenged girl.
Here's my question, and I'm hoping that those of you who are much more knowlegable than I can point me in the right direction.
We have a 1970 Safari, (with one 12V battery) and all our electrical is original and in great working order. When camping without shore power (which is what we do most often), we would like to be able to plug in our awning lights, charge our cell phones, and occasionally play a portable DVD player for the kids. Is there a realistic, simple, economic solution for installing a small inverter that could provide us with some 120 power for these small luxuries?
Would this be a huge install, or is there an easy solution?
Any advice would be great!
Mellody
MTsafari is offline   Reply With Quote
Old 03-29-2010, 08:58 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Think in 12VDC terms. Your cell phone, lap top, potable DVD player ect. can operate and charge from a 12VDC supply. You can even get awning lights that run off 12VDC. You can also get an inverter that plugs right into the 12VDC outlet(the thing that looks like a cigarette lighter). It will be a small inverter but with one battery you will need to be a little careful with the power usage.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-29-2010, 09:14 AM   #3
MTsafari's Avatar
1970 23' Safari
Thanks, Lee. Would using the type of inverter you described drain the batter significantly and quickly (say from just running awning lights or a portable DVD player?)
Old 03-29-2010, 09:22 AM   #4
1967 22' Safari
1960 Caravel
Images: 8
Try to go 12VDC first. When you run a inverter just the process of changing 12VDC to 120VAC will use up power you will never see.
How fast this will drain the battery depends on a lot of things. How efficient the inverter is. How much power the DVD player uses. What kind of bulbs are in the awning lights and how much power they use. ect. Sorry no quick easy answer with this one.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Az Rv'rs challenged..some say.. and retired otherwise dene57k Member Introductions 6 12-25-2009 09:12 AM
Inverter magwa Land Yacht/Legacy Motorhomes 35 10-17-2009 11:55 AM
Defeated or challenged? boatdoc Off Topic Forum 32 03-23-2007 04:34 AM
Solutions For the Parking Challenged muddy_hollow Off Topic Forum 1 07-28-2006 05:07 PM
electically challenged 61Overlander Electrical - Systems, Generators, Batteries & Solar 16 08-26-2003 02:18 PM
