Old 04-08-2012, 12:45 PM   #1
leander , Texas
Help - electrical issue!
we have a 2011 International Serenity 28' with solar package. was camping with the family this weekend and had to depart early due to electrical issues. We were plugged into shore power. had no issues the first 2 days, then i noticed the lights started dimming and getting brighter. then the a/c started blowing warm air. batteries were not charging from solar or shore. by the time we hooked up to leave, even plugged in, it was like the trailer was only wanting to run on the 12v system. the lights wouldn't even come on, electric jack wouldn't work etc. checked fuses and breakers visually and all look okay. any ideas? i know it's under warranty, but if i am missing something simple here i would like to give it a shot before dropping it off with the dealer. thanks in advance for any input, Jason
mastercaster is offline   Reply With Quote
Old 04-08-2012, 12:53 PM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Jason,
"checked fuses and breakers visually and all look okay."
Did you try re-seting all the breakers, off completely then back on.
If so sounds like the converter may be the culprit.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 04-08-2012, 12:58 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Sounds as though something is amiss with the converter...while plugged into shore power it should be delivering power to your 110 outlets and charging the batteries at the same time...all systems should work, both 110 and 12v, including your AC. If your jack was not working, it's a sign your batteries are compromised since the jack is wired directly to the batteries and does not depend on the converter for its power.
TB & Greg and Abbey Schnauzer
#3954
Old 04-08-2012, 01:04 PM   #4
Ottawa , ON
There isn't a switch that has to be changed when you connect to shore power on those trailers?
Old 04-08-2012, 01:40 PM   #5
leander , Texas
no, there is no switch. just a battery disconnect. i did reset all of the breakers. this is the weirdest thing to me. while out there, we were able to run the coffee maker this morning. but everything was like it was getting half power. literally. the fantastic fans on setting 3 moved the same or less air than setting 1 normally. the led lights throughout the trailer were very dim. we just got home and i plugged it in to the house. it shows the batteries are charging, fans and lights seem to be working normally. have yet to try the a/c though. i am worried that got hit. could a surge at the park have caused this? we never noticed one, but we were gone from the trailer quite a bit. i don't, i'll try the a/c in a few. fingers crossed. i'll let you know. thanks again for the input/help. keep any ideas coming!
Old 04-08-2012, 01:52 PM   #6
2005 19' Safari
GLENDALE , AZ
The first thing I'd do is check the battery fluid levels and voltages (with battery cables disconnected). From your description, it sounds like one or both may be discharged.
Old 04-08-2012, 01:58 PM   #7
leander , Texas
according to the meter in the trailer, the batteries are/were at 0% charge. after i plugged it in at home, it showed that the batteries were charging, and they made it to 15%. when i just went out to try the a/c, the batteries were back down to 0%. the a/c does seem to be working though. so why won't the shore power, solar panels, driving home, not charge the batteries. the batteries are sealed, so not water to check/add. the trailer bought new about 14 months ago.
Old 04-08-2012, 02:07 PM   #8
Ottawa , ON
You were (are?) in a campground, you say. Did you check the voltage available out at the pole?
Old 04-08-2012, 02:10 PM   #9
leander , Texas
no, i didn't. didn't have anything to check it, and with wife and kids in tow, we were ready to just head home.
Old 04-08-2012, 02:12 PM   #10
leander , Texas
but again. everything now seems to be working (fingers crossed it stays that way) except for the charging of the batteries. on all of our vehicles, including previous airstream, batteries tend to last about 4 years here in central texas. could the batteries both be bad so soon?
Old 04-08-2012, 02:46 PM   #11
2005 19' Safari
GLENDALE , AZ
If your batteries show zero charge, I'd take them out (or disconnect them from all trailer wiring) and charge them overnight with an auto-type battery charger. Then, check the voltage. If they look like they are holding a charge, they may be OK. However, one or both may have been overcharged, and the electrolyte is gone.
Before buying new batteries, charge these fully; then take them to AutoZone, Pep Boys, O'Rielly's etc. to have them load tested (for free). It's possible they are just discharged.
By the way, if you still have the OEM Interstate batteries, they could be bad. One of ours failed after about a year; and the other, about six months after that.
You may wish to search this site for "Marine Battery Isolator Switch", a relatively inexpensive modification that solves both parasitic drains during storage and overcharging problems.
Old 04-08-2012, 02:53 PM   #12
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
It IS very possible that there was an issue with the power at the campground...you might get one of these (or similar) voltage meters (pic below) to plug into a convenient 110 outlet so you can track the voltage coming into the rig from shore power...the green area is the "safety zone"...
The battery monitor associated with your solar system reading 0% or 15% while plugged into shore power is worrisome to me...it should read 100% when you are plugged into shore power, no matter what the condition of your batteries...if it doesn't, it is a sign of a converter issue.
Name:	AC Voltage Meter.jpg
#3954
Old 04-08-2012, 03:04 PM   #13
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
If your batteries have been discharged completely for some time, or discharged completely a few times, they have likely lost most or all of their capacity to hold a charge. Start with the easy stuff... the trailer is telling you the battery is dead, so pull them, put them on a charger, and then test them. You'll get all kinds of weird stuff happening with fried batteries. Also - the jack not working it 100% related to your battery condition, and is the quickest way to tell your battery is dead - as the jack is directly wired.
Now, why you'd have dead, new, batteries is another issue... leaving the trailer without it being set to 'store' will drain your batteries... a few months, or week if it is cold, will drain a battery just from sitting. I like to leave mine plugged in at home...
Friday is offline   Reply With Quote
Old 04-08-2012, 03:13 PM   #14
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Have you thought about buying a surge protector. There was recently a post about the reliability of the power at some parks and it seemed as everyone recommended a surge protector that protects the electrical system from both high and low voltage. they were not in expensive however based on your experience I believe I will get one.
urnmor is offline   Reply With Quote
Oh No, Marathon issue! Bruce B Tires 158 11-08-2013 02:37 PM
WBCCI Constitution Revision Help Howard Lefkowitz WBCCI Forum 4 04-15-2012 04:16 PM
Help - electrical issue! mastercaster Batteries, Univolts, Converters & Inverters 21 04-09-2012 01:56 AM
Missing my backend! Help Olivebranch Waste Systems, Tanks & Totes 2 04-08-2012 09:15 PM
help with pic. please cjohnson Forum Admin, News and Member Account Info 2 04-07-2012 04:52 PM
