Old 07-14-2012, 09:06 PM   #1
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Help converter making funny noise!
Ok, I just got my 12v system back on line after the shell off. I had some wires backwards on the stove fan but got them back the right way. The converter is making a funny noise. Like a guitar string being plucked. when it does this the lights dim.
It makes the noise every 15 seconds or so, like it charging up to do it. It does it whether the lights are on or not?
It didn't make this noise when I took it out, and it's only been sitting in the garage.
Any ideas? It's dark know so I won't be able to do anything till the morning.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-14-2012, 09:12 PM   #2
1974 Argosy 20
Kooskia , Idaho
First, turn the converter/charger off. It sounds to me like you have an automatic resetting circuit breaker somewhere with a short on it. It keeps trying to reset, and each time it does it loads the converter/charger, makes noise, and dims the lights.
You don't want it to continue all night, that is bad for everything.
Old 07-14-2012, 09:15 PM   #3
richinny's Avatar
2011 34' Classic
have you tested the battery?
Ricky
Old 07-14-2012, 09:19 PM   #4
purman's Avatar
1968 28' Ambassador
Batteries are good, just came of the trickle charge, And I disconnected the cables from the battery when I came in. I will try turning that part off tomorrow. and unplugging it form where the shore power comes in. I didn't have this hooked up at the time.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-14-2012, 09:29 PM   #5
richinny's Avatar
2011 34' Classic
i agree with idroba, it sounds like a 12v breaker resetting. leave everything disconnected and verify the polarity on your converter & battery connections.
Ricky
Old 07-15-2012, 09:15 AM   #6
purman's Avatar
1968 28' Ambassador
Thats what it was. the polarity light was blinking when it made the strum noise. Switched the battery cables around and it works fine. I was using black and white and the trailer was using white and red. I read the wires going into the convertor backwards.
Thanks for the help.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
