Old 06-25-2014, 09:37 PM   #1
billiards's Avatar
rochester , Minnesota
Help: battery terminal wire
Changed old batteries for fresh....main cables are fool proof, but forgot where the small eyelet black wire was attached.......neg or pos. Thanks
billiards is offline   Reply With Quote
Old 06-25-2014, 09:49 PM   #2
richw46's Avatar
Lexington , Kentucky
All black? No red on the terminal at all??
A black wire is probably going to ground. Do you have an electric tongue jack
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 06-25-2014, 11:13 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
My trailer is in storage, so I can't check, but I had a black wire attached to the plus terminal. 99.9% sure it was electric tongue jack. Follow the wire. If it goes to jack, it goes on plus.
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-25-2014, 11:33 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Black = Positive
White = Negative
In most RV's
Old 06-26-2014, 12:31 AM   #5
Mexray's Avatar
1978 28' Ambassador
Morada , California
This issue is somewhat confusing for older RV's...
12 volt wiring colors used to be:
Pos = Red
Neg = Black
As RV mfg's began to conform to RVIA standards they changed their wiring colors to conform:
Pos = Black
Neg = white
As you can see, the BLACK went from Neg (old) - to Pos (new, current) in wiring harness'...
I found this out in grand style when installing the battery in our 2000 vintage Lance truck camper...Whoa - no red Pos wire - what gives...till I looked at the wiring diagram...Surprise on me...!
Ray & Pat; Morada, CA
Old 06-26-2014, 05:47 AM   #6
Zil
egg harbor city , South Jersey
Best advice is to follow out the wire and find where the other end is attached.
You could check for continuity to see if it grounds.
Zil is offline   Reply With Quote
Old 06-26-2014, 05:53 AM   #7
billiards's Avatar
Thanks......a million, jack
Battery terminal harness? TxBxSx Batteries, Univolts, Converters & Inverters 3 10-25-2012 08:21 AM
Three Terminal Device under front service bay:what is it? 66ambassador Lights - Interior & Exterior 3 06-23-2012 10:54 AM
What kind of plug terminal is this? bookem666 Electrical - Systems, Generators, Batteries & Solar 3 08-02-2011 08:14 PM
(pics) Going to Germany....Blount Island Terminal leefields Shipping & Export/Import 2 09-18-2007 09:11 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
