Old 09-26-2010, 08:15 PM   #1
1972 25' Tradewind
Arboles , Colorado
Have you replaced a Univolt fan?
Call me impatient or bad at searching these forums but I haven't seen any that suggest replacing the original fan in the Univolt. Andy at Inland RV says the Univolt rarely fails so I want to just silence that noisy old fan instead of replacing the unit. I was thinking of installing a 4" muffin fan. Anybody replaced the fan? With what? Thanks!
2coldnpagosa is offline   Reply With Quote
Old 11-30-2010, 04:20 AM   #2
1972 25' Tradewind
Arboles , Colorado
Here's an update...After I had a friend come visit for the week and stay in the LY I knew it was time for a fix! The racket was just too much to ignore. I pulled the converter which wasn't bad at all cept for the cramped space it resides in. On the bench it was a few 1/4" screws to remove the cover, blow it out with air and study the fan. The fan can be disassembled while in the unit by using a stubby flat blade screwdriver and removing the 2 screws holding it all together. I then cleaned the motor shaft with 000 steel wool, blew it off with air again, put a little general purpose grease to it, reassembled and whalaaa! Nice and quiet! Boy I love the fact these ole items are repairable and not throw-away's as todays products seem to be.
Old 11-30-2010, 07:28 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Good to hear back on how this went. Nice results.
5 meter Langford Nahanni
Old 11-30-2010, 08:28 AM   #4
The original Univolt, for your Airstream, did not have a fan.
Someone prior, must have installed a replacement, perhaps from a later year.
Univolt Replaced with Inteli-Power 9280 vswingfield Batteries, Univolts, Converters & Inverters 25 01-05-2010 09:11 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
Fan wheel on Heater needs to be replaced JDJohnson Winter Living 12 02-15-2009 10:18 AM
replaced univolt - keeping new battery good jpancini Batteries, Univolts, Converters & Inverters 2 09-11-2008 06:51 AM
Mostly good power after Univolt was replaced... ricjones1138 Electrical - Systems, Generators, Batteries & Solar 1 04-10-2006 06:39 AM
