Old 02-16-2015, 03:28 PM   #1
1974 Argosy 26
Joshua Tree , California
Grounding connections for Power Supply
I'm replacing the copper plumbing on our 1974 Argosy 26' with PEX. There's 2 ground connections coming from the back of the Triad TU 331 Converter. One is soldered to the plumbing. One follows the vent stack below deck - I assume to the frame. I know it's a bad idea to solder to PEX😏. What should I do with that connection?
StarckMad is offline   Reply With Quote
Old 02-16-2015, 06:00 PM   #2
2007 22' International CCD
Tie them both to the frame of the AS at one point. The one to the copper was to ground the plumbing for lightning protection as well. PEX doesn't have the same issue electrically as copper. Mine is grounded just forward of the rear bumper to a big bolted in brass lug. There are two ground wires in the lug.
KE4GNK/AE
Old 02-16-2015, 08:18 PM   #3
1974 Argosy 26
Thanks MK. I've since noticed the ground wires come from the breaker box, not the the power supply. I imagine the answer is the same tho....
Old 02-16-2015, 09:31 PM   #4
Yep. They should start at the ground buss in the breaker box. The bare ground/safety earth/green ground wires to your outlets should also terminate there. There also is a neutral buss in there for the white wires. Do NOT tie that buss to ground. It has to float in an AS. The neutral lead goes out of the breaker box to the shore power connector and then to the plug at the end of the shore power cord.
KE4GNK/AE
Old 02-17-2015, 06:51 PM   #5
2014 23' FB Flying Cloud
Mill Valley , Left Coast
Probably doesn't need saying but when splicing copper to aluminum use lugs rated for both metals and use lots of "goop". CuAl aid, no-ox, penetrox, or whatever flavor you can locate.
JB
jbxx is offline   Reply With Quote
Waterproof power cord connections???? silverwoman Electrical - Systems, Generators, Batteries & Solar 14 01-28-2013 06:26 PM
Power Converter & Power Supply Land Shark Batteries, Univolts, Converters & Inverters 8 05-11-2010 09:51 AM
Shore power & water connections - where? malconium General Repair Forum 13 05-06-2008 11:36 AM
generator grounding JK3500 Generators & Solar Power 23 06-19-2007 03:59 PM
Proper Grounding of 120V input PhilMateo Electrical - Systems, Generators, Batteries & Solar 24 05-11-2006 07:07 PM
