Old 07-12-2007, 11:11 AM   #1
1998 35' Cutter Bus Diesel Pusher
London , ontario
Ground faults
Hi We Have a 1998 cutter .If we plug in to a ground fault plug the braker kicks off. I put a tester , positive on the fram and the neg stuck in the ground . The tester showes 6.78 volts . We also some times get a shock when we touch the body of the rv and are touching the ground . Were do I start to look . If we are not pluged in to a AC out let and are only running the inverter we show nothing on the tester . Norm
ngwalkabout is offline   Reply With Quote
Old 07-12-2007, 11:20 AM   #2
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
We had this problem on our 1978 Ambassador. It turned out that I had no ground at the outlet where I plugged into shore power.
Tom
#8848
tlavergne is offline   Reply With Quote
Old 07-13-2007, 11:13 AM   #3
DayStreamer
grizzy's Avatar
2001 19' Bambi
Mesa , Arizona
I had the a similar problem a few years ago with the external GFI tripping (although I never had power feedback through the trailer body). My problem turned out to be one loose connection ( I believe it was the common) on one outlet. I guess the voltage fluctuation was just enough to trip the GFI. Once I tightened the connection the problem was gone. This was a tough one to find because all outlets, even the one with the loose connection, worked fine when I didn't have the external GFI attached.
Dave
DayStreamer
2001 19' Bambi
02 Avalanche
Mesa Arizona
AIR #5591
grizzy is offline   Reply With Quote
Coast To Coast Rv Resorts ALANSD On The Road... 30 09-07-2011 09:40 AM
Should I ground my airstream? robkelly1 Electrical - Systems, Generators, Batteries & Solar 10 04-20-2006 11:28 AM
Generator Paul Daugherty Airstream Motorhome Forums 19 08-09-2002 08:47 AM
Univolt Operation melprice Electrical - Systems, Generators, Batteries & Solar 11 06-17-2002 04:13 PM
Next Classic Airstream Motorhome Rally winner WBCCI Rallies & Events 38 04-24-2002 11:22 AM
