Old 04-05-2015, 06:02 AM   #1
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
Ground fault
Okay, probably something I should already know...but...
I use a digital meter/filter at the power post and power wouldn't pass through with an E-2 fault indicating a ground fault. Campground was soaked a couple days before (under ground water box hookup was even submerged and required bailing), so my first thought was that there wasn't usable power. Checked the 50amp circuit with an adaptor to see if it erred and the meter passed through without error.
As I really don't know what causes a ground fault and what the downsides areódid I do a really stupid thing by not moving to a different site or not?
Thanks, Al
Question: better to be a successful pessimist or a failed optimist?
Al & Robin
2018 Airstream 23FB Flying Cloud
2015 F150 XLT 3.5L EcoBoost, 4WD
almcate is offline   Reply With Quote
Old 04-05-2015, 06:27 AM   #2
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
A ground fault occurs when electricity travels outside an intended path and tries to get to the ground by the shortest route. Further it is when the "hot" wire touches the ground wire or anything else that is grounded. Could be the box, water or one of the other wires directly. It's what usually trips a fuse or circuit breaker.
If your protection device gave you a fault I would not use the electricity from that site and request another site and again plug in the surge or fault protector. I am not an electrician and don't even like working around electricity, but this is what I was told at a campground where my surge protector gave me a fault.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 04-05-2015, 09:07 AM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I may be mistaken, but i dont think your filter would detect a classical ground fault in the power box. It senses currents flowing through it to/from the trailer. It may be telling you there is no connection to the ground wire in the power box or something else. Did you try it with the trailer disconnected?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Ground fault using generators pjmoser Electrical - Systems, Generators, Batteries & Solar 17 10-31-2015 08:14 PM
Ground fault light on 1972 argosy LOREN SILVA Electrical - Systems, Generators, Batteries & Solar 4 07-10-2013 08:41 AM
Neutral Ground Fault on ciruit 1 ViewRVs Argosy Motorhomes 10 06-05-2013 07:31 PM
Ground fault circut breaker Pop Rivet Electrical - Systems, Generators, Batteries & Solar 1 08-06-2009 10:42 AM
Ground-Fault if Honda is grounded or not Driver1 Generators & Solar Power 19 07-11-2009 10:20 AM
