Old 01-26-2014, 09:53 PM   #1
1972 25' Tradewind
San Mateo , California
Gray wire (for power light on control panel) ???
Can somebody tell me where or how to connect the Gray wire that goes to the power light on the control panel, once you upgrade to a parallax fuse panel. I'm doing this on a 1976 Trade Wind.
Tweb is offline   Reply With Quote
Old 02-02-2014, 09:50 AM   #2
1988 25' Excella
Trumbull , Connecticut
Hello Tweb. If you search the forum for "power on light not working" you will find your answer. I upgraded my 88 with the boondocker and I love. If you want the power on light to work you will have to modify things as the search forum indicates. I just pluged a small AC meter into an outlet to indicate power.
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 04-21-2014, 12:10 AM   #3
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I used a 120 volt relay to send 12 v power to the light.
1988 Running Light Exposed Wire vhariable Lights - Interior & Exterior 2 06-25-2011 08:56 PM
Control Panel, overhead light rverforlife General Interior Topics 0 05-10-2011 10:40 AM
New Light for the cedar closet Dan@LED4RV Commercial Listings 6 04-07-2011 07:04 PM
Build your own Control Panel DanielB 1973-1974 Excella 500 0 03-21-2011 05:59 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
