11-07-2005, 08:52 PM
1975 31' Sovereign
Oxford
, Mississippi
Got a hummmm
I have noticed a hummm coming from the control panel everything seems to be working fine. Is this normal.
Becky
11-07-2005, 08:54 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Becky
Becky,
I hope your hearing is better than mine...I suspect the hum is coming from the Univolt (battery charger/converter) Run a board search on Univolt... But as long as everything is working I wouldn't be worrying.
Aaron
WBCCI #XXXX AIR #2495
11-07-2005, 09:36 PM
Becky, as Aaron says, this will be the Univolt. I assume you are plugged into the 120 volt mains AC power. If you unplug this, and run on the trailer battery for a minute, the hum should stop . The hum is caused by the alternating current reversing direction 50 or 60 times per second ( depends which side of the Atlantic you're on), and setting up sympathetic vibrations. You've probably heard a neon tube light making the same noise. If the noise bothers you at night, you can run on the battery overnight, or upgrade the Univolt (the trailer's battery charger), to a more quiet, modern and efficient charger such as the Intellipower. (Try the search facility for more than you thought you needed to know about them).
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
11-07-2005, 11:49 PM
Put a bird on it!
1976 Argosy 20
SANTA BARBARA
Oh I have wondered the same thing over several very loud buzzing sleepless nights! Glad I am not the only one!
11-07-2005, 11:58 PM
2005 19' Safari
1968 24' Tradewind
Rural
, Delaware
The Univolt in my Tradewind hums as well. It seems the more the power draw, the louder the hum. It still works great though. I'll be interested to see how it acts with new batteries.
11-08-2005, 03:55 AM
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
My last Argosy purchase, the PO after I paid him said well, I never hooked into electicity, it made a wierd humming sound from under the sink in the back, we just ran extension cords.... It was the Univolt, works fine but the sound would be alarming if you were not aware.........
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
11-08-2005, 07:11 AM
Retired.
, At Large
60 cycle hum
It is the same sound (only louder) that you get from the ballast on flourescent lights, and for the same reason. It is a 60 cycle hum from the transformer part of it, and is nothing to be alarmed about in and of itself.
The older Univolts tend to overcharge batteries, and for that reason, and the humming, many folks replace them.
11-08-2005, 07:22 AM
1979 30' Argosy
Havelock
, where we park it
Intellipower
Best investment made.. would be the first thing to be replaced for any older trailer ... no more humming ... .. and saves the life of your battery
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
11-08-2005, 09:59 AM
1975 31' Sovereign
Oxford
, Mississippi
Glad to hear that it is nothing major since I found the floor under the gaucho rotted out seems like the next few weeks are going to be working on the floor and then we will work on upgrading that hummmm.
Becky
11-20-2005, 05:49 PM
72 Argosy 24
1973 24' Argosy 24
McComb
, Mississippi
Yeah, Working on the floor is my new project too. I never even thought about upgrading the Univolt but after reading the threads I guess I will do that too...Wonder which one to get and how much they are?
Good luck on the floor.......
Toby
11-20-2005, 05:55 PM
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Toby
Check out Vintage Trailer Supply
They have a nice one on sale!
Just ordered one for the 76 31' we are working on!
www.balrgn.com
11-20-2005, 06:20 PM
Retired.
, At Large
Toby
Intellipower 45 amp should be sufficient for your coach, I have seen them online for $145.99 plus shipping.
10-24-2011, 09:01 AM
1984 31' Excella
Lees Summit
, Missouri
Hot spot in floor
Would the humming inverter also make a hot spot in the floor behind the couch next to the charger switch??
10-24-2011, 01:19 PM
Short answer: yes.
Long nerdy answer: An inverter is a device to produce AC from DC. It is often used in trailers to power domestic TVs and other AC devices from 12 volt battery power. If your device is in fact a transformer (AKA a converter), like the Univolt or Intellipower, it produces a change in voltage of the AC, then rectifies this to DC to charge the trailer battery(ies). The transformer often has a soft iron core, and heat is produced by the resistance of the iron core to induced eddy currents. This may be the heat you are feeling.
Short nerdy answer: Hysteresis is my thesis!
Nick.
10-24-2011, 01:34 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Toby
Toby,
I upgraded to this IOTA 3yrs ago and couldn't be more pleased with the outcome.
Plus it's on sale now, great deal!!
10-24-2011, 01:39 PM
Aluminum Falcon Mechanic
1972 31' Sovereign
Wesley chapel
Originally Posted by nickcrowhurst
Short answer: yes.
ling.
Nick.
Plot the curve and get back to me...
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Ford? Chev? Dodge?
imagine |
Tow Vehicles |
7 |
07-30-2005 09:55 PM |
