Old 12-10-2007, 12:44 PM   #15
New Borockton , Alabama
Images: 21
Chris,
I just got your email and had not seen this thread. Andy above is correct in that those are both positive and need to be joined. Per your email, the white then is the negative and you should be good.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 12-10-2007, 01:06 PM   #16
1966 30' Sovereign
Goleta , California
Hi Zep,
I just did the wiring you suggested at the fuse box and smoke started coming out of the fuse panel. So, I put it back as it was (in the diagram).
I also joined the red and blue wires on the positive terminal at the converter. The white wire is on the side of the box on what looks like to be a ground screw. Power between fuses 1 and 3 stopped.
Cris
Cristina1966 is offline   Reply With Quote
Old 12-10-2007, 01:42 PM   #17
1966 30' Sovereign
Goleta , California
One more thing. I tried tp connect the white wire on the negative terminal of the converter instead of the side screw (which looks like a ground terminal). If I do this, there are sparkles.
Old 12-10-2007, 02:07 PM   #18
Images: 21
Chris, the top screw and the side terminal on the XADC are both chassis ground. Normally that is a solid copper wire comming from the frame somewhere. I can't tell from your photos which is which so I would stop and have it looked at to be sure. Normally the blue and red or positive but anybody could have changed things around. "Sparkles" aren't good.
Old 12-10-2007, 02:33 PM   #19
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Cristina,
Andy and 68Overlander are right. I thought you said the other terminal (with the blue wire) was (-) negaqtive. My bad. You want both (+) wires together to go the the red traced side. Tie the real negative lead (-) to ground (the blue trace in my doctored photo).
Zep
Originally Posted by Cristina1966
Hi Zep,
Cris
Old 12-10-2007, 06:19 PM   #20
1966 30' Sovereign
Goleta , California
Problem solved!!! The Probelm was with the wiring of the converter. The solution was to put both red and blue wires on the positive and the white wire on the negative. The ground was not the white wire. I will need to attach another wire to ground the converter to the shell. Thank you all for the input. You guys are wonderful!
Cris
Old 12-10-2007, 07:52 PM   #21
Images: 21
Outstanding! Atta boy.....girl.
Old 12-10-2007, 09:27 PM   #22
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Rats! I said green is seldom ground in trailers and automotive, I should have also said white is also seldom ground in trailers and automotive. Good you've found it!
NevadaGeo is offline   Reply With Quote
New Power Converter 66 Tradewind Batteries, Univolts, Converters & Inverters 10 07-06-2015 02:04 PM
wiring of new power converter Joe1261 Batteries, Univolts, Converters & Inverters 1 03-21-2007 08:13 PM
What is a good converter? 72Blazerod Electrical - Systems, Generators, Batteries & Solar 2 05-19-2006 07:35 AM
Power Converter Died??!! JimGolden Electrical - Systems, Generators, Batteries & Solar 5 11-17-2005 07:18 PM
Power Converter? Maediris73 Batteries, Univolts, Converters & Inverters 1 05-17-2005 08:14 PM
