Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 12-10-2007, 12:44 PM   #15
68 Overlander
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
Chris,
I just got your email and had not seen this thread. Andy above is correct in that those are both positive and need to be joined. Per your email, the white then is the negative and you should be good.
Old 12-10-2007, 01:06 PM   #16
Cristina1966
Profile:  1966 30' Sovereign
Goleta , California
Hi Zep,
I just did the wiring you suggested at the fuse box and smoke started coming out of the fuse panel. So, I put it back as it was (in the diagram).
I also joined the red and blue wires on the positive terminal at the converter. The white wire is on the side of the box on what looks like to be a ground screw. Power between fuses 1 and 3 stopped.
Cris
Cristina1966 is offline   Reply With Quote
Old 12-10-2007, 01:42 PM   #17
Cristina1966
Goleta , California
One more thing. I tried tp connect the white wire on the negative terminal of the converter instead of the side screw (which looks like a ground terminal). If I do this, there are sparkles.
Old 12-10-2007, 02:07 PM   #18
68 Overlander
Commercial Vendor
Images: 21
Chris, the top screw and the side terminal on the XADC are both chassis ground. Normally that is a solid copper wire comming from the frame somewhere. I can't tell from your photos which is which so I would stop and have it looked at to be sure. Normally the blue and red or positive but anybody could have changed things around. "Sparkles" aren't good.
Old 12-10-2007, 02:33 PM   #19
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Cristina,
Andy and 68Overlander are right. I thought you said the other terminal (with the blue wire) was (-) negaqtive. My bad. You want both (+) wires together to go the the red traced side. Tie the real negative lead (-) to ground (the blue trace in my doctored photo).
Zep
Originally Posted by Cristina1966
Hi Zep,
Cris
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 12-10-2007, 06:19 PM   #20
Cristina1966
Goleta , California
Problem solved!!! The Probelm was with the wiring of the converter. The solution was to put both red and blue wires on the positive and the white wire on the negative. The ground was not the white wire. I will need to attach another wire to ground the converter to the shell. Thank you all for the input. You guys are wonderful!
Cris
Old 12-10-2007, 07:52 PM   #21
68 Overlander
Commercial Vendor
Images: 21
Outstanding! Atta boy.....girl.
Old 12-10-2007, 09:27 PM   #22
NevadaGeo
Profile:  1978 31' Excella 500
Genoa , Nevada
Rats! I said green is seldom ground in trailers and automotive, I should have also said white is also seldom ground in trailers and automotive. Good you've found it!
NevadaGeo is offline   Reply With Quote
wiring of new power converter Joe1261 Batteries, Univolts, Converters & Inverters 1 03-21-2007 08:13 PM
What is a good converter? 72Blazerod Electrical - Systems, Generators, Batteries & Solar 2 05-19-2006 07:35 AM
Power Converter Died??!! JimGolden Electrical - Systems, Generators, Batteries & Solar 5 11-17-2005 07:18 PM
New Power Converter 66 Tradewind Batteries, Univolts, Converters & Inverters 9 05-25-2005 04:33 AM
Power Converter? Maediris73 Batteries, Univolts, Converters & Inverters 1 05-17-2005 08:14 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
