Old 10-19-2012, 04:58 PM   #1
1980 20' Caravelle
Coeur d alene , Idaho
Good Battery-No 12 volt Lights?
1980 Caravelle, Napa charged my battery, inside panel says battery is GOOD, Checked all fuses--look fine! No interior 12v power for lights or water pump. What do I check next? Heading to fish Kamp Sunday--Bummer! Don
glacierrunne is offline   Reply With Quote
Old 10-19-2012, 05:10 PM   #2
SteveH's Avatar
Common Sense , Texas
I had a '75 model that developed an open circuit on the battery distribution/fuse panel at a bolt that carried the power from one side of the board to the other, and had the same symtoms as yours. You need a 12 volt meter, or trouble light to test where you do have 12 volts, and where you do not. It's really a pretty simple system to trace out.
Old 10-19-2012, 05:35 PM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
On more than one occasion I have had fusses that looked good, but were blown in a way that did not show. Use an test light and make sure there is power on both ends if the fuse when it is in place. Also, over time, oxidation can form between the fuse and the holder "clips". Don't know just how that happens. but it does.
Also, check to be sure your battery is grounded to the frame well. I had that ground connection go away on our Caravel a number of years ago.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 10-19-2012, 05:38 PM   #4
1988 32' Excella
Robbinsville , New Jersey
I have seen were the fuse clip is connected there was corrosion and a bad connection.
Old 10-19-2012, 06:27 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Best guess is a bad ground connection. Even if it looks good, where it joins the body, take it apart and clean the connection.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 10-19-2012, 06:34 PM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
For a quick check of your battery ground connection, use a plain old jumper cable and connect from your battery negative to a good, paint free area on the frame of your trailer.
Old 10-20-2012, 09:59 AM   #7
1980 20' Caravelle
I have a 12 volt meter--I'll start checking--thanks for all the help!!! Don
12 volt
Battery question Ofdtruckie Batteries, Univolts, Converters & Inverters 19 11-14-2011 05:19 PM
Should interior lights work with no battery but with Tow Vehicle connected bocotim Electrical - Systems, Generators, Batteries & Solar 12 11-03-2011 10:06 AM
How long can my battery cable be - and what gauge wire? robwok Electrical - Systems, Generators, Batteries & Solar 3 10-20-2011 09:52 AM
CTEK Battery Chargers wayneskid Electrical - Systems, Generators, Batteries & Solar 1 07-09-2011 12:13 PM
