Originally Posted by solo pilot
Installed new outlet for charger using existing wire. Try disconnect bare ground?
So you installed a gfci outlet specifically for the converter, if I read this correctly.
Other than its normal purpose the ground wire doesn't have any additional purpose in a gfci. A gfci simply looks for a difference in current between hot and neutral. It can take as little of an imbalance of 5 mA to trip. Converters usually have good size capacitive circuits so as the capacitor charges it causes a current imbalance betwee inlet and outlet of the inverter because some of the charge is being stored in the capacitor. Easily enough to trip a gfci outlet.
One other common cause is wiring the hot supply and load wires backward. If the gfci has more outlets downstream they're both black so it's easy to swap during install. See professional electricians do it regularly.
