Old 07-01-2009, 10:11 AM   #29
Jitano's Avatar
2008 27' Safari FB SE
Santa Fe , New Mexico
Thumbs up
Once again I thank all off you that responded to my need to know about generators. What a great group.
Jitano
Jitano is offline   Reply With Quote
Old 07-04-2009, 06:14 AM   #30
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
If you like to boondock I would seriously consider buying an inverter which converts 12v DC to 110v AC. You can go cheap or very expensive for inverters. The nice thing about inverters is that you don't need to run the generator every time you want to watch TV or run the hair dryer. I only use my Honda EU2000i to recharge my batteries or to run the microwave. The inverter takes care of most AC needs.
I love my little Honda EU2000i. I've owned mine now for 6 years. I can hold a normal conversation right next to mine when in use. Amazing!
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-04-2009, 06:53 AM   #31
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Rich,
Someone who knows more than I on this subject will likely comment or correct me (I don't have a generator yet, just looking!) but the Honda 1000 and 2000 are both supposed to be capable of putting out 8 amps at 12vDC which to me sounds much more than a trickle charge & I would have thought that would charge batteries fine.
Maybe I'm missing something - be interested to see what others say.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-04-2009, 07:09 AM   #32
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by Wingeezer View Post
Rich,
Brian.
For a deep cycle marine battery 8 amps is a very low charge, it would take 8-10 hours to bring an 80% discharged battery back up to full charge. That is a lot of generator time. Here is a website that has a lot of decent information on 12 volt systems and recharging.
Aaron
WBCCI #XXXX AIR #2495
Old 07-04-2009, 07:09 AM   #33
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I have not connected the coach batteries directly to the the 2000 for charging, but it has charged the car battery in short order.
Running the 2000 for an hr. or so every couple days, with the coach plugged in keeps the Lifelines charged up very well.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 07-05-2009, 05:33 AM   #34
Wingeezer's Avatar
2005 30' Classic
Aaron
Aaron, thanks for that explanation and the link! Brian.
2005 Classic 30'
Old 07-05-2009, 08:34 AM   #35
Airstream25's Avatar
1995 25' Excella
1982 34' Limited
Albuquerque , New Mexico
Images: 21
Send a message via Skype™ to Airstream25
Not everybody has clear sunny non stop days. I have been in places where if you saw the sun twice a day for for a week you were considered fortunate.
Aaron
Aaron, What you say may be true. However, if you notice, Jitano, the person who started this thread lives in the same area that I do.
Solar is great.
Jitano New Member
Profile: 2008 27' Safari FB SE
Santa Fe , New Mexico Posts: 3
Airstream25
KE5CKG on 2 meters
AIR #10274
Airstream25 is offline   Reply With Quote
Old 07-07-2009, 11:24 AM   #36
Jitano's Avatar
Arrow Jitano
All:
I have decided to not purchase a generator. Was leaning toward a Honda 2000 but instead will be mounting a 110 Watt PV on the roof. Our needs while boondocking will be simple, lights (I am going to change to LED or at least lower watt bulbs),refrigerator and heat. I will make coffee on the stove with the old perk pot and will take pre ground coffee with us. All to say, the 110Watt should keep the batts charged. The only item I am leaning toward would be an inverter to charge up a lap top, or portable electric tools. What are the thoughts out there about size of inverter? I probably will only need one plug into the inverter.
Old 07-07-2009, 11:25 AM   #37
Jitano's Avatar
Originally Posted by Jitano View Post
All:
I know what I know but only the Shadow knows
Old 07-07-2009, 12:54 PM   #38
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
All:
For your needs I think that is a good idea. I bought a 1500watt Xantrex inverter at Costco a few years ago for about $75. It wires directly to the batteries and comes with two 110v plugs. I used one for a permanent plug further forward in my rig. I used an old three-prong extension cord and cut the end off and made an inverter only dual 110v plug. Works great for the laptop, satellite TV, and charging portable tools and cell phones.
1958 Overlander
4CU 1st VP
Old 07-07-2009, 01:02 PM   #39
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
could you use the cig litter to put a car converter in and use it that way?
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-07-2009, 01:14 PM   #40
dstalzer's Avatar
2005 25' Classic
I changed out the 4 reading light bulbs with LED lights from Superbrightleds.com in my Classic and would recommend this if you are planning to boondock with only the 120 watt solar panel. These lights are a little pricey, but draw only minimal current. The other benefit is the lights are extremely cool instead of burning hot which would also be better when not using the A/C.
Dennis
dstalzer is offline   Reply With Quote
Old 07-07-2009, 02:50 PM   #41
Wingeezer's Avatar
2005 30' Classic
Dennis
I did the same thing and was happy with the results - not quite as bright as the halogens but adequate and I do like the reduced heat too.
I had to buy two different types of led bulbs for our reading lights,
The ones over the bed were "hockey puck lights" and for them, I needed led's with side connection pins.
The ones over the sofa are swivel lights and needed connection pins at the back of the led. I suspected - and it turned out to be so - that for these light fixtures, the pins on the led's as delivered would not be long enough to reach the socket before the led assembly would foul the metal reflector, so I had to solder on short extension wires - maybe 1/2."
It worked fine and so far, the led's do not come loose in the sockets while traveling as I feared they might!
I think that next, I will try replacing the automotive wedge bulbs in the three bulb fixture over the dinette with led's and then maybe try one of the fluorescents. I hope to ensure they are all the same colour temperature (warm white in my case) for consistency.
I do like led's !
Brian
2005 Classic 30'
Old 07-07-2009, 03:07 PM   #42
dstalzer's Avatar
2005 25' Classic
G4 LED lights
For the hockey puck style lights I used Superbright G4-WHP10-D warm white and for the drop down swivel lights I used their G4-WHP15-T warm white lights which required no soldering, but just plugged in.
Dennis
West Wyoming Fly Fishing & Free Camping Ray Eklund Boondocking 54 11-16-2015 01:55 PM
Free-Free-Free -- Twin Bed Setup - 1955 Flying Cloud Tx Air 1950-1955 Flying Cloud 9 03-14-2010 09:07 PM
Free 1972 Overlander Interior Parts - Get 'em while they are hot (and free) amitchell Interior Restoration Forum 25 03-03-2009 05:02 PM
Camping or Luxury Camping? Devoman Our Community 47 08-26-2006 09:57 PM
Camping Anyone? 74Tradewind Forum Rallies & Meet Ups 6 09-06-2002 02:58 PM
