Old 12-12-2015, 07:48 PM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Fuses vs Circuit Breakers for 12v Protection?
I'm installing a new converter in a 69 Globetrotter. The old one had the 12v fuses built right in it for the 3 12v circuits. The new one does not.
So I was wondering the difference in circuit protection between a 12v fuse and a 12v circuit breaker. I understand a circuit breaker will interrupt current flow when it gets hot, and reset itself when it cools down. It would be easier to use just the circuit breakers.
My 66 Trade Wind has both fuses and circuit breakers as delivered from the factory, see photo below.
Can I use just circuit breakers and forget the fuses?
David
Name:	1311 12v Fuse Panel.jpg
Old 12-12-2015, 08:05 PM   #2
1974 Argosy 20
Kooskia , Idaho
When a fault developed, a fuse blows and cuts the power off completely until it is replaced (and the fault is found). The automatic reseting circuit breakers I think you are referring to keep trying to reset themselves and in doing so, keep sending power to the fault, over and over and over. Eventually something fails, like the wire insulation and then you have a potential fire.
Automatic reseting 12 volt circuit breakers are not a good solution at all for the circuits. There are a very few situations that they are useful, and even then, one can question that they be used.
I cannot recommend them.
Old 12-12-2015, 09:06 PM   #3
1979 23' Safari
Wayland , New York
Couldn't agree with idroba more! 12v auto resetting circuit breakers are a disaster in the making.
On a separate note my I phone spell checks idroba with "odor a" made me wonder if anybody ever came up with a user name based on spell check suggestion being something funny. Just a thought.
Old 12-12-2015, 09:20 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
While auto-resetting circuit breakers are probably not good for general use, there is nothing wrong with manual resetting ones. You'll never be wishing you had one more fuse.
Marine suppliers like Defender Industries and West Marine have a wide variety of fuse and circuit breaker panels.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 12-13-2015, 10:05 AM   #5
1974 Argosy 20
Kooskia , Idaho
I have been known to have intestinal issues, so maybe spell check is working just right.
Old 12-13-2015, 03:05 PM   #6
2002 31' Classic
Houston , Texas
"I was wondering the difference in circuit protection between a 12v fuse and a 12v circuit breaker. I understand a circuit breaker will interrupt current flow when it gets hot, and reset itself when it cools down. It would be easier to use just the circuit breakers.
Can I use just circuit breakers and forget the fuses?".
David:
Certainly you can.
Fuses are short-circuit protection, NOT overload protection, and are usually sized (depending on the purpose/designer) 4-10 times the full load current. Breakers are for overload protection FIRST, and short circuit as a secondary facet. Usually, they have "long time characteristics" for overload, and "short time characteristics" for short circuits. In house circuits, a 20 amp breaker is NOT loaded to 20 amps, it's normal upper loading is 16 amps; between 16 and 20 amps, the "trip element" begins to heat, and will eventually trip because of the buildup of heat. Seventeen amps may take an hour (for instance) and 19 amps might go in five minutes. If there's a short in the operating circuit, a low level short (say, 25 amps) it might trip in two or three cycles, while a 30 amp short might trip in a half cycle. All this depends on a bunch of things, but it's typical.
Fuses have the advantage that they FORCE you to hunt for the cause. Their disadvantages start with "I don't have a spare".
Auto reset breakers do NOT normally respond with getting hotter and hotter each time they operate, only to eventually burn up, or even to harm the conductors. If chosen properly, they'll safely continue to operate through many operations. Consider relay contacts ---- same making and breaking. The auto resets have one of the same characteristics of fuses: they don't force you find the problem as quickly. Same's true for breakers in general, in fact.
But about the third time a breaker trips, you don't have to consider replacing it like a fuse. Just size it correctly, and remember it's for DC, and NOT AC.
General question: Why do vehicles almost exclusively use fuses?
Kent
Registered Professional E.E., Texas
KMarshall is offline   Reply With Quote
Old 12-13-2015, 03:11 PM   #7
2002 31' Classic
Houston , Texas
Fuses and circuit breakers.....
Just dawned on me (as I hit the send button) that I should have made a clear distinction about auto reset versus manual reset breakers.
Use the manual reset types.....
Old 12-13-2015, 03:12 PM   #8
dznf0g's Avatar
Oswego , Illinois
The breakers in my 2007 are not self resetting. They have a little black reset button on the end of them.
-Rich-
Old 12-13-2015, 03:40 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I will stick with fuses, especially the modern blade type. They are simple, cheap and easy to check to see if they are blown. Anything mechanical like circuit breakers can become problematic. I am referring to the 12 volt system specifically.
Old 12-13-2015, 03:56 PM   #10
lewster's Avatar
Naples, FL , Hood River, OR
The only place RVIA specifies auto re-set circuit breakers for a DC circuit is on the 12VDC feed going to your trailer brakes. The reasoning should be obvious.
If you look at the 12VDC positive bus bar at the front of all newer Airstream trailers (at least from 2000 on), you will see 4 auto re-set circuit breakers connected to a copper bus. One is where the house battery connects. The second is where the 12VDC disconnect solenoid is connected which then runs to your 12VDC fuse panel and the other 2 are used for loads not controlled by the disconnect solenoid, like CO detectors (parasitic loads).
This bus bar is usually located in locations that are rather difficult to access. Ever wonder why????
Old 12-13-2015, 05:07 PM   #11
dznf0g's Avatar
Oswego , Illinois
Likewise with autos....headlights have self resetting breakers for obvious reasons.
-Rich-
Old 12-13-2015, 05:09 PM   #12
dznf0g's Avatar
Oswego , Illinois
Mine has manual resets at the buss and all circuits in the "fuse" panel.
-Rich-
Old 12-14-2015, 09:58 AM   #13
Bathurst , New Brunswick
Smile
Hi
I did an overhaul of my 71 Travelux electrical. Not quite the same as airstream ,but the same principle. I used an automotive fuse block with the connectors for each circuit. I also used an electrical rail with snap in connector blocks , for those wires that needed to be connected. I was in the process of fixing it , so please excuse the mess when i took the picture . You probably will have to zoom in to see what i mean. hope this helps. PS- i agree with not using auto circuit breakers, they can sometimes heat up from trying to reset themselves and pit the contacts inside, and stick
mrfixit51 is offline   Reply With Quote
Old 12-14-2015, 11:21 AM   #14
Just learned to add a photo on the forum thks
Originally Posted by mrfixit51 View Post
Hi
12v
Circuit breakers in '09 International 25FB donna01 Electrical - Systems, Generators, Batteries & Solar 6 03-13-2011 02:15 PM
Circuit Breakers Alumanutz Lights - Interior & Exterior 1 09-11-2008 08:02 PM
Circuit Breakers Tripping bgarver Electrical - Systems, Generators, Batteries & Solar 2 11-16-2007 10:52 PM
Circuit breakers,94 33ft Motor Yacht rayschell Batteries, Univolts, Converters & Inverters 4 07-10-2005 11:35 AM
Electric Heaters Tripping Circuit Breakers streamlean General Motorhome Topics 11 01-20-2004 09:29 PM
