Old 01-05-2015, 11:23 AM   #1
2014 23' FB Flying Cloud
Mill Valley , Left Coast
Fuse Replacement
Hi all!
I am a new owner of a 2014 23 FB FC.
I am an Electrician and Engineer with 40 yrs. experiance ( 58YO).
One of the first things I've changed in the Electrical is the ATO fuses.
I've changed them to Indicator ATO fuses, it is a really cool idea.
The fuses have a small LED across the fuseable element. So if the fuse
blows, it lights up! Here is a link to the product that is available at any good auto parts store. But much cheaper at the link.
ATO Smart Glow Fuses
Next will be a better voltage monitor then a portable Solar set up.
J.B.
jbxx is offline   Reply With Quote
Old 01-05-2015, 08:33 PM   #2
New Borockton , Alabama
Images: 21
Smart glow fuses are pretty cool and been around awhile. We've thought about including them with our power centers.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 01-05-2015, 10:39 PM   #3
1974 Argosy 20
Kooskia , Idaho
If you replace your Paralax converter/charger with a Progressive Dynamics 46xx series a new fuse block is included which has LED indicator lights for each circuit which come on if the fuse blows.
Old 01-05-2015, 10:46 PM   #4
Images: 21
That is true with the 4600 series. The stock parallax units don't have that nor any of the deck mounts of course. Any fuse block can be configured with those fuses mentioned.
fuse box replacement on older airstream durans54 Electrical - Systems, Generators, Batteries & Solar 2 02-28-2006 03:31 PM
Fuse Block replacement - help Craig Electrical - Systems, Generators, Batteries & Solar 6 10-13-2004 03:01 PM
fuse burn outs Ed L Our Community 5 06-16-2003 10:10 PM
Fuse size? working Electrical - Systems, Generators, Batteries & Solar 5 05-08-2003 10:11 PM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
