Old 06-10-2008, 08:53 PM   #1
1975 31' Sovereign
Pensacola , Florida
Fuse panel question
Thanks everyone so far for the great advice...now another question. I am getting the Xantrex 60amp converter and I am planning on replacing the old fuse panel with a new blade style panel so I can run automotive fuses off of it. My problem is this, in my owners manual for my 75 31' sov. I was looking at the fuses and some were showing that it called for 40 and 50 amp fuses. The only fuse panels that I have found have had a max rating of 30amp fuses. Does anyone have any suggestions or know where I could purchase the right fuse panel or should I just stick with the old one that's in there.. all your help and comments are appreciated. Thanks
RandyG is offline   Reply With Quote
Old 06-10-2008, 09:10 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
You may need to combine two different panels. The make high amp blade fuses, but they're bigger. Check out a marine supply.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-10-2008, 11:46 PM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
40 amp fuses are available in the standard size, but it is hard (impossible?) to find fuse blocks for th standard blade fuses that are rated at more than 30 amps per position or 100 amps overall.
I use these fuse blocks with 40 amp fuses in two positions (of the 8 available) for the batteries. I've got a 45 amp converter (Intellipower 9200 series) that has its own dual fuses, so I connect the inverter directly to the buss bolt.
ATC®/ATO® Fuse Panel w/o Grounding Pad
I don't use any high power inverters, so there's no normal sitution where I'll have a need for more than 25 amps or so at any time. If something goes haywire and the amps jump up, the overwhelming probability is that they'll jump way past 40 amps and fuses will blow right away--I'm not concerned that the fuse block will exceed it's short-term amp capability.
Zep
converter, electrical, fuse panel, univolt, fuse
Third wire on the fuse panel help flashbackk Batteries, Univolts, Converters & Inverters 9 05-01-2008 08:27 PM
fuse panel question BigSky Electrical - Systems, Generators, Batteries & Solar 6 02-26-2007 07:45 PM
Where is my 12volt fuse panel??? Blu_Hwy_Lady Electrical - Systems, Generators, Batteries & Solar 5 07-02-2006 12:37 PM
Fuse panel bluebonnet Electrical - Systems, Generators, Batteries & Solar 7 08-15-2004 10:42 AM
What size fuse for 12-volt panel? paddy79 Electrical - Systems, Generators, Batteries & Solar 4 05-23-2004 08:39 AM
