Old 01-21-2008, 03:04 PM   #15
Kajtek1's Avatar
1965 22' Safari
Orinda , California
Originally Posted by OakHill
But do they have a product that is so able to conduct electricity to so much surface area?
My 24V bus conversion has about 2 tons/1200 sq ft of stainless steel siding.
Big enough?
Kajtek1 is offline   Reply With Quote
Old 01-25-2008, 01:06 PM   #16
1968 28' Ambassador
Ridgecrest , California
Previous posts reference use of a surface mount fuse block, and a heavy duty commercial breaker. Can anybody point to a link to examples of the circuit protection devices? I did a quick look in my Cole-Hersee catalog, and examples didn't pop out at me.
Maturango is offline   Reply With Quote
Old 01-25-2008, 01:23 PM   #17
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
Maturango--I've seen installations that use the "Class T" fuses. Here's a link to what they look like from fellow AirForums member "OutsideSuppl"'s website.
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 01-25-2008, 01:38 PM   #18
MATURANGO, I think this is one of the type of fuses you are talking about. They have also in line power fuses.
Parts Express - Amplifiers, Head Units, Speakers, Wiring Kits, Subwoofers, Dampening and check part #263-624 for $30. They have others in the power distribution pages. good luck.
Live and LET live
FrenchBern is offline   Reply With Quote
Old 01-25-2008, 06:24 PM   #19
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Stinger fuse holders
I'm not sure if this is what your looking for. I am installing these, there waterproof and use AGU fuses. Stinger Electronics :: Where It's Loud Robert
ID:	53181   Click image for larger version
bertro is offline   Reply With Quote
Old 01-26-2008, 06:34 AM   #20
Just checking if I could post pic of it.
Wow it worked.
Live and LET live
Old 01-26-2008, 08:42 AM   #21
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
On the right is the Bussman 50 amp combination switch/breaker that I used on the positive side of the battery. Having read this thread, I think I will now buy another one for the negative side.
Blue Sea Systems
Sergei
SmokelessJoe is offline   Reply With Quote
Old 01-26-2008, 09:21 AM   #22
flitzwhopper's Avatar
1976 Argosy 24
Tempe , Arizona
FT (Fuse Tease)
French Bern - That's it! So this is a tease - right. How much for a source for the device? The forums are good...
Donna & Mike
Cowboy up! or go sit in the truck
Charter Member Four Corners Unit
WBCCI #2417
flitzwhopper is offline   Reply With Quote
Old 01-27-2008, 10:04 AM   #23
1968 28' Ambassador
French Bern --
The fused battery terminal you found is very interesting. What's your experience with availability of the AFS "mini wafer" fuses these use? As far as I can tell, they're unique to the car audio folks and/or this product? Can you find the fuses at, say, a well-stocked NAPA?
Old 01-27-2008, 02:12 PM   #24
2007 22' International CCD
Tunbridge , Vermont
HERE IT IS, and it is a lot less expensive buying it directly from these guys. This is the breaker I use on my 8,000 lb winch on my tow vehicle. If something does cause it to trip, a little arm pops out and you can reset it with finger pressure. Check out this site:
50 Amp Automotive Circuit Breaker
Also, if you enter "12 volt 50 amp circuit breaker" into Google you will find breakers priced from $7 to $59, but it is clear from the photos that the ones marked "Heavy Duty" and "RV use" are what you should have, in my opinion.
Pete in Vermont
AIR 26504
WBCCI 2980
2007 22 ft International CCD
2007 Tahoe 4X4
Hensley Arrow
[prior AS: 1986 Excella 32 ft ]
Whoever said "Money can't buy happiness" never owned a custom made bamboo fly rod.
Pete Vermont is offline   Reply With Quote
12v Negative Problem jrk247 Electrical - Systems, Generators, Batteries & Solar 24 10-01-2006 08:48 AM
Battery Fuse jcferguson Electrical - Systems, Generators, Batteries & Solar 12 12-16-2005 06:38 PM
puzzled by fuse at battery connection Tin Tortuga Electrical - Systems, Generators, Batteries & Solar 2 03-25-2005 03:13 PM
Fuse panel for 1-battery system paddy79 Electrical - Systems, Generators, Batteries & Solar 15 06-23-2004 08:30 AM
