Old 11-12-2008, 10:56 AM   #1
Carson City , Nevada
Fuse/12V Distribution Panel
I have replaced the battery in my Argosy with a pair of 6V golf cart batteries, replaced the converter with a 60 amp Xantrex converter/charger, and run new power cables. The original (glass fuse) distribution panel remains. It is giving me grief and needs to be replaced.
Question --- does anyone know of a marine grade blade fuse distribution panel that has 5 or 6 <30A fuse positions and a 'master' Maxi Fuse that protects the whole panel? I have not found one, thought I would ask here before I make something special to get this fixed permanently.
Mike
Mike S is offline   Reply With Quote
Old 11-12-2008, 10:59 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Have you tried Boater's World, or West Marine?
Old 11-12-2008, 11:42 AM   #3
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Here is what I did:
I purchased a parallax fuse panel and a black plastic project box with a cover and some standoffs for the board from radio shack (fuse panel came from bestconverter.com).
The ground and 12v are both protected by fuses. The fuse inside the box is for the 12v. The bare wires in the upper left corner are the trailer ground wires. The circuits are rated for 20 amps except where you see the piggyback which is rated for 30 amps. The battery cables were left over from another project.
crispyboy is offline   Reply With Quote
Old 11-12-2008, 04:03 PM   #4
New Borockton , Alabama
Images: 21
Crispyboy,
That round hole where it says Conv Pos is where you connect the positive cable from the converter. A ring terminal with a screw and nut to secure it. It will power all nine circuits if needed.
Then you can run two 30 amp fuses for reverse polarity.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 11-12-2008, 08:22 PM   #5
Yes, and they do not have anything in the Catalog od local store that answers the problem.
I COULD just make something up that would work using a wire bus, standard multi-position blade fuse board, and separate 60 Amp maxi-fuses to protect both panel and ground. The batteries are fused at the mounting location, so no worries there.
Old 11-13-2008, 10:05 AM   #6
crispyboy's Avatar
1994 30' Excella
68 Overlander,
I connected the convertor 12v wire to the lug on the back side of the panel - so the 30 amp circuit it is essentially backfed.
12v
Broken Fuse Block In Distribution Panel - How Best To Repair montanaandy Batteries, Univolts, Converters & Inverters 12 06-01-2015 08:01 PM
Distribution panel upgrade nd48463 Batteries, Univolts, Converters & Inverters 6 05-23-2009 01:14 PM
Low voltage distribution panel...Help k9s2go Electrical - Systems, Generators, Batteries & Solar 4 12-29-2006 01:54 PM
12v fuse panel location? coldduc All Argosy Trailers 5 05-26-2004 06:15 PM
