Old 09-16-2015, 03:25 PM   #1
2014 23' FB Flying Cloud
Mill Valley , Left Coast
Furion 30A plug recall
Just for S&G I opened up the 30 A outlet that was under recall for poor connections on my 2014 23' FC. Everything looked tight and secure and no undue heat signature while running the AC off shore power. But I did notice one thing that concerned me. The #10 romex that comes out the back of the plug and turns down the outside is under constant pressure against the inside aluminum skin. In fact without putting pressure on either the inside or outside skin the outlet is about 1" larger than the space between the inside and outside skins making it a constant point of abrasion (this is with the insulation cleared from the outlet). Another piece of not so fine craftsmanship to be noted.
jbxx is offline   Reply With Quote
Old 09-16-2015, 04:51 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Could you please provide a link to the NHTSA recall you referenced in the title to your thread?
Thank you.
Old 09-16-2015, 06:27 PM   #3
2016 30' Classic
Erie , Colorado
I'm not sure it was an NHTSA recall. For sure it was a recall from Airstream.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 09-16-2015, 06:33 PM   #4
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
How does one find out more about any and all recalls from Airstream
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 09-17-2015, 01:54 PM   #5
Couldn't find my original notice but I googled it and found this:
Link to follow.
https://www.automd.com/recall/campaign_c106637/
J.B.
Old 09-17-2015, 07:12 PM   #6
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Thanks.
DoublTrouble is offline   Reply With Quote
to plug in or to not plug in...that is the questions 4hartungs Batteries, Univolts, Converters & Inverters 39 04-23-2014 03:44 PM
replacing 30a plug funkill Electrical - Systems, Generators, Batteries & Solar 8 07-13-2010 06:51 PM
30A Upgrade to 30A + 20A Wayne Olson Classic Motorhomes 10 12-12-2006 03:51 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
