Old 08-15-2014, 08:32 PM   #43
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
The fuse is where?
If the battery was charged and the fuse was between the battery and the converter, the lights should have come on from battery power. Hopefully the fuse is between the battery and everything else, including the fuse/distribution center. If not, you may still have a problem.
Assuming all is really OK, congratulations! As I have said before in similar situations myself, I'd rather be lucky than good, anytime.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-16-2014, 07:17 AM   #44
1974 21' Globetrotter
staten island , New York
Al
I am going to say, and this is an uneducated guess that the fuse is between the battery and everything else, converter and fuses.
dcorona is offline   Reply With Quote
Old 08-20-2014, 10:15 AM   #45
Superannuated Member
Aironius's Avatar
2001 19' Bambi
Beaver Lake , Arkansas
dcorona, the refrigerator requires the same amount of heat to operate, whether it comes from propane, a 110v heater or a 12v heater. But if it is running on 12v the converter will always be in charge mode due to the load. It never will drop to the maintain level and so it will cook the battery just like an old "non-smart" charger. If the refrigerator is set to 110v whenever it is available, the battery saving function of the charger can work. If the refrig does not cool well on 110v, fix that.
Aironius is offline   Reply With Quote
CROCODILE HUNTER Steve Irwin Killed by Stingray rseagle Off Topic Forum 14 10-03-2006 06:58 PM
Someone Killed Bambi .. airstreamcaravel Our Community 4 05-15-2003 10:26 PM
