03-15-2017, 09:21 PM
2016 27' Flying Cloud
Hartsburg
, Missouri
Frank’s lithium battery and inverter upgrade
Well after weeks of research and asking questions on this forum I am proceeding with my lithium battery and inverter/charger upgrade. After seriously considering Victron and GBS battery packages like many others on this forum have used I went a different direction and bought a Lithionics 330 AH battery. I choose Lithionics because it was competitively priced compared to Victron, was a single battery as opposed to wiring multiple batteries in parallel, is built to order in the U.S. and ships within a few weeks, has an internal BMS that simplifies wiring, and after several discussions with their engineer and CEO I felt they were a solid company. I certainly acknowledge the great packages and technical support AMsolar provides, but I enjoyed researching and sourcing some of my own components and liked the Lithionics battery. Lithionics also just became a Victron dealer and they programmed both devices for their battery before shipping them to me. Lithionics does not have an online retail site but if you make a inquiry using their online contact form they will follow up with you. They appear to primarily work with manufacturers and RV dealers but will work with "knowledgeable DIYers". They were very responsive to my questions.
Step one was to remove the original Lifeline AGM batteries--by the way the batteries and all the original electronics I took out are for sale and only have about 3 months use on them! Next I removed the original converter and AC panel so I could install a new split AC panel so I had a main panel and subpanel to be powered by inverter. I went with a progressive dynamics split panel recommended by Lewster and Troutboy.
Next I had to route two lengths of stranded marine 10/3 AWG triplex wire from the AC panel to the inverter location to provide the AC power to the inverter and then back to the panel for the inverter powered circuits. This will eventually be covered with some wiremold.
The only practical option for location of the battery and inverter was under the bed, as other have done:
Now it’s time to connect up a disconnect switch and fuse on the positive side and a disconnect and shunt for the battery monitor on the negative side. I used 3/16 x 1 inch cooper bar and some 4-0 cables made up at a local battery shop.
Since I mounted the Victron inverter /charger horizontally I removed the top cover to provide better ventilation.
I haven’t decided where I want to ultimately mount the battery monitor, or if I am going to get a remote panel for the inverter, but for now everything is reasonably accessible through the door on the front of the bed.
Last step was to hook up the mppt soalr controller with my original stock solar panels. Next project is to replace the two stock 53 watt panels with four 100 watt panels.
Everything appears to be working. I do need to still program a "charge assistant" in the inverter/charger so when the temperature sensor on the battery monitor detects temperatures are below 32 F it will disable the charger. I'm awaiting delivery this week of the temperature sensor and the cable to connect by laptop to the inverter to do this. Thanks to several people on this forum who've been very helpful with their responses to my earlier posted questions and pms!
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
03-16-2017, 08:31 AM
2004 28' Classic
Monument
Very nice job!! What was the cost of the Lithionics battery?
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
03-16-2017, 10:43 AM
2015 27' FB International
Howard
, Ohio
Looking good! [emoji4]
03-16-2017, 11:29 AM
1955 22' Safari
Laredo
Ad?
How much for the Lifeline AGM's?
03-16-2017, 12:10 PM
2008 25' Classic
Full Time
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
Nice work.
@living.somewhere.yonder | Instagram
03-17-2017, 12:39 PM
Refugee from Napa, CA
2015 25' Flying Cloud
Formerly Napa
, On the road
What is the weight of the new battery? Cost?
Instagram. Alluminator
03-17-2017, 01:28 PM
2022 25' Flying Cloud
NCR
, Ontario
great job
can you post a schematic of your work and a link to the supplier
cheer
03-17-2017, 01:30 PM
Cave Creek
Attachment 281518Attachment 281522
Attachment 281521
Attachment 281515Attachment 281523
Attachment 281520
Attachment 281519
Attachment 281516
Attachment 281517
What is the model of the Progressive Dynamics dual panel?
Pete B55
2017 Classic
2017 F-250
03-17-2017, 01:59 PM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Looks great. Love that Victron hardware. Been thinking about ebaying all my Blue Sky stuff and inverter and upgrading. I love Victron's integration with it's systems and the bluetooth and app are nice for us techies.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
03-17-2017, 02:45 PM
Houston
Please describe your AGM set up
Your location
And price
Steve Stanton
asherstanton@gmail.com
03-17-2017, 09:17 PM
2018 25' International
Sioux Falls
, South Dakota
Frank & Fran: Extremely "knowledgeable DIYers".
Wow Extremely thoughtful, well designed, and professional job!
Clear & clean presentation.
We hope, someday, to be able to replicate your fine work.
It seem that the RV solar power space is becoming a competitive market.
More choices, better pricing, helpful suppliers, and more convenience for customers.
Pretty soon, Airstreamers will be able to place complete solar power system orders to be shipped to them or their installer. All we will need to do is to specify our AS's year, model, and length. Bingo.
Supply and Demand still works!
Great Job, and good luck down the road. Thanks for sharing.
03-19-2017, 07:46 AM
2017 23' Flying Cloud
Parker
Frank, well done! Looks great and I envy all that space and how well you used it. I'm still waiting for my batteries (Victron), and told they will be here in a week or so.
I highly recommend the remote for the Victron multiplus, but you have easy access, so maybe it doesn't matter.
I hope you get great use out of the system!
Troutboy
03-19-2017, 12:50 PM
2017 30' International
Broomfield
Frank nice job. I like the simplicity of the install.... Question for you based on the photos -
Seems that the only 12v device that you have connected to the batteries themselves is your MPPT charge controller.
Regarding other 12v devices in the trailer (overhead lights, etc..) are you powering those from the converter which is fed 120v from the inverter when not on shore power?
IE - when not on shore power, do you first invert 12v -> 120v to feed the panel and converter, then use the stock converter to convert back down to 12v to power the 12v panel that feeds the various accessories connected to the 12v bus?
Thanks!
03-20-2017, 09:01 PM
Hartsburg
, Missouri
Thanks everyone for the nice comments. I was out of town a few days and will try to get caught up with questions.
wulfraat and waninae39: I labeled the picture below in lieu of a schematic. There's is a positive wire that goes from the copper bar between the battery and disconnect switch to the original airstream positive bus bar to power the dc circuits, so its fed by the battery and also the converter as long as the disconnects are turned to on, but battery only if the positive disconnect is off.
For those asking about the supplier and cost of the battery: I got the battery from Lithionics Battery after contacting them via there website. I negotiated a price with them with the understanding I would post about my install to raise awareness about their product with Airstream owners. All I can say about price is they are competitive with Victron battery packages from other dealers. For a limited time in 2017, Lithionics Battery is offering the batteries for sale factory-direct. Once the OEM and dealer networks are established, they will be sold through RV dealers. You can contact the factory in Clearwater Florida directly at 727-726-4204, or, by info@lithionicsbattery.com."
Check out the video link in KJRitchie's post for more info on Lithionics. The battery weighs 115 lbs.
Bold: So far I am liking the Victron equipment a lot too. The end user documentation is not great but with help from dealers and this forum you can figure out what you need to. I haven't decided whether to go with the blue tooth connections or remote panels or some combination. I hoping eventually the inverter will also go blue tooth like the battery monitor and mppt so its all blue tooth!
Asherstanton, sorry my AGMs are sold.
The new split AC distribution panel is the PD55B006 intended for 50 amp service with a 30 amp sub panel that I bought from Best Converter. My only complication with it was the sub panel had three slots which let me use a 30 amp breaker for the main and two tandem 20 amp breakers for four circuits on the inverter. Because I needed tandem breakers to get 4 circuits I could not use the full-sized gfci breaker so I put a 20 amp gfci outlet in the line in lieu of the breaker. I don't know if there is better model that gives more slots for the inverter powered subpanel.
Remaining tasks are to program the Victron inverter charger to shut the charger off when temperatures are 32 and below and to replace my two stock 53 W panels with 4 100 W panels--will do a separate post about that. Then to take the trailer down to the Texas coast for a week in April to try try out the new systems!--Frank
Frank & Fran
Equalizer Hitch
03-20-2017, 09:56 PM
Broomfield
Thanks Frank. Super helpful. Love the simplicity.
Did you install a D.C.-D.C. Converter (like the victron Orion) to regulate the voltage from the tow vehicle plug so as not to charge the battery with an incorrect voltage from the tow vehicle alternator when towing? Or do you simply disconnect the battery from the system when towing to avoid the 13.x volt charging source?
I assume the latter would be sketchy if ever the trailer separated from the tow vehicle as there would be no 12v source onboard to lock up the brakes once the breakaway switch is tripped....
03-20-2017, 10:15 PM
Hartsburg
, Missouri
I asked Lithionics if I should be concerned about the tow vehicle as a charge source and they suggested their built in BMS could handle it. But I've alos wondered about putting in a disconnect so I could shut off the tow vehicle as a 12 v source, and let the brakes work off the the lithium battery and solar? -- Frank
Frank & Fran
Equalizer Hitch
03-20-2017, 11:05 PM
Broomfield
Interesting.... I thought charging at anything other than the recommended voltage range (14.0-14.4v for Lithionics per their website) was a no-no for lithiums...
I believe you could disconnect the main TV 12v charging line from the hot 12v bus in the trailer to eliminate charging but the brakes would still be sent voltage from a secondary variable voltage line in the trailer connection. I think You'd have to look carefully at the wiring schematics to be sure...
But I'm no expert
03-20-2017, 11:15 PM
Parker
I thought it was important to separate this as well. It is for the Victron setup, and can damage the BMS in the Victron setup. That is why they have the Orion D.C.-DC as you mention. I'm not sure what it does to the battery, maybe Lewster can answer if the battery is at risk.
This is the explanation on an AS install from AMsolar, and they call out BMS shorting.
"Because the BMS on the Essential system acts on the negative side of the batteries (ground control), the negative (or chassis) from the tow vehicle with the alternator is at a slightly different voltage than the negative output of the lithium system. This creates a design challenge since shorting the negative output of the lithium system to the tow vehicle chassis would damage the BMS.
In a van conversion or coach, the issue of having two different negatives is easily resolved by routing the output of the lithium battery through the Orion 12/12 DC converter. The negative output of the Orion converter can then be tied to the chassis and all positives for the DC loads get re-routed to the positive output of the Orion. If the total DC load is more than 30A, multiple Orion converters can be connected in parallel. Inverters, or anything else that can have their negative isolated from the chassis will just connect directly to the output of the lithium battery system without going through the Orion converter.
In trailers, the issue of having two different negatives is solved differently. In this situation, the Orion converter goes on the input side of the lithium system, thus isolating the trailer from the tow vehicle’s chassis. When this is done, the Orion converter has to be modified so it’s output voltage is 14.2V instead of the factory 12.0V. This is accomplished by carefully tuning a potentiometer inside the converter that is accessible when the cooling fan is removed. This design will limit alternator charging current to 30A, but it will protect the BMS from having it’s input and output short circuited."
Troutboy
03-21-2017, 05:52 AM
Hartsburg
, Missouri
I'm going to check back with the engineer at Lithionics on the possibiity of the tow vehicle charge voltage damaging the battery or BMS and will report back what I find out. In the mean time I will investigate if its possible to use a disconnect on the charge line from the tow vehicle connection whilie letting the tow vehicle continue to operate the breaks and not disabling the breakaway switch function for the brakes--I think this should be possible. --Frank
Frank & Fran
Equalizer Hitch
