Old 10-15-2014, 10:48 AM   #57
Durango , Colorado
Originally Posted by mefly2 View Post
OK ...if and only if you have a place in which to plug it ... late model AS have eliminated the 12vdc power points and replaced with USB ...
Well yes, but I have a small inverter just like that one and I never use it anymore. Pretty much all my devices charge via USB so I don't need to invert to 110.
However I agree that Airstream should have an option for those who want the 12vdc power points for other uses.
RVDreamer is offline   Reply With Quote
Old 10-15-2014, 10:50 AM   #58
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
RV dreamer
I think the USB plugs require AC power? Would they work with factory inverter if so? Just out I curiosity ?
PharmGeek is offline   Reply With Quote
Old 10-15-2014, 10:55 AM   #59
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Not sure about 2015. My 2014 has one by the DVD player.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 10-15-2014, 11:06 AM   #60
Durango , Colorado
Originally Posted by PharmGeek View Post
RV dreamer
I have not picked up my 2015 Serenity yet so I don't know what circuit the USB plugs are on. However the USB standard is for about 5vDC out so I don't know why you would need the inverter. I would assume these run off the battery circuit.
Old 10-15-2014, 11:28 AM   #61
lewster's Avatar
Naples, FL , Hood River, OR
RV dreamer
USB outlets are wired directly into 12VDC circuits. No conversion required. Optimally, they use a dedicated circuit with independent fusing. Most of the USB ports that I install have a max. rating of 15 amps.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 10-15-2014, 04:40 PM   #62
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
So long as the devices you use can charge via USB, you're all set - you just need a USB or USB / Lightning cable. If that's not the case, you may still need an inverter so you can plug in the requisite power brick and charge up your laptop. Our tow vehicle has a built-in inverter / AC outlet, so we can also charge from there while driving.
Old 10-16-2014, 09:20 AM   #63
mefly2's Avatar
2015 25' FB Eddie Bauer
Our 2015 has NO 12vdc power points.
600 Watt Inverter PWirtz Batteries, Univolts, Converters & Inverters 13 01-10-2015 12:01 PM
Generac iX 2000 Watt Portable Inverter Generator Frank&Mike Generators & Solar Power 21 11-06-2014 06:20 PM
5000 BTU/hr AC and 1,000 Watt Genny TouringDan Furnaces, Heaters, Fireplaces & Air Conditioning 36 08-01-2012 08:46 PM
Need options for 3000 watt inverter Dwight Batteries, Univolts, Converters & Inverters 1 08-30-2011 08:55 AM
Yamaha EF3000iSE 3,000 Watt DL46 Batteries, Univolts, Converters & Inverters 2 09-28-2010 03:16 PM
