Old 10-05-2014, 07:50 AM   #43
Elmsford , New York
For those of us not able to "do it yourself," are there any (probably large) authorized Airstream dealers with personnel capable of upgrading the solar panels and 1,000 watt inverter system on the 2015 Airstream Classic 31' trailer who can do the job expertly and safely, even if it is more money? Any suggestions? The factory will not, I have learned, and I want a high-end, professional job that will not come back to haunt me a year from now!
RussH is offline   Reply With Quote
Old 10-05-2014, 01:45 PM   #44
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
In my limited experience, the AS dealer in our area, while capable and competent, doesn't really know much about solar. When we asked them to install a system, they just went with a Zamp 150 Watt solution. It's OK, but if I had it to do over again I would have gone to a solar energy expert and had a much better system installed for the money. At the time I didn't know enough to ask for something better or to consider going to a third party.
YMMV, but Lewster here on the forums seems a perfect example of the kind of person I would have considered for the job if I had known then what I know today.
Old 10-05-2014, 07:40 PM   #45
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
We used out factory 1000w inverter on our first boondocking trip this weekend - sounds dumb I know but somehow I assumed before that TV components would work off grid off dc power or some such
Quickly realized to swap plugs to inverter outlets and was good to go
Used for that - charge cell phones and run. Small fan at night
My fan kicks on as soon as you power it up - you can hear it when lying on the bed - which is fine cause that's why I use the small fan - love that noise when I sleep (luckily)
Glad I got this unit - although not sure how quality the unit is - worked for our needs fine over the weekend
PharmGeek is offline   Reply With Quote
Old 10-05-2014, 10:12 PM   #46
1974 Argosy 20
Kooskia , Idaho
The WFCO 1000 watt inverter takes between 1.76 and 1.9 amps when just on, doing nothing, or powering such small loads as cell phone chargers. So, be aware that you can use a lot of your battery power when you leave it on. Every 10 hours it will consume 17.6 to 19 amp hours from your batteries.
Old 10-05-2014, 11:05 PM   #47
mefly2's Avatar
2015 25' FB Eddie Bauer
Lewster here on this forum is the man for your upgrades. He does installs in OR and IIRC FL ...
Very good credentials and experience - as well as advice.
Old 10-06-2014, 08:48 AM   #48
Costa Mesa , California
Does anyone know what the standby power is for the inverter on a 2007 Airstream Interstate? I replaced all my halogen lights with LEDS and replaced the Propane Detector which used 76ma with a more efficient one at 46ma to extend my house batteries when dry camping. I never looked at the efficiency of the inverter which I have never used so I thought it was off or not connected since my 110v plugs are all dead until I plug in shore power (plugs go live immediately)or run the generator (plugs go live after about 30 seconds). If I have Gen on and AC running, power to microwave goes off. Inverter not big enough to run either AC or MW but am I supposed to be able to use plugs for TV or appliances through inverter when on battery power alone or when engine is running?
Option7 is offline   Reply With Quote
Old 10-06-2014, 11:25 AM   #49
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Option7 - did you opt for an inverter? You will have I believe special outlets labeled as inverter outlets if you got the inverter option?
In my standard 110 outlets - my TV and DVD player all cut off also until I plug into shore power or generator - I have to swap the plugs and turn on the inverter
Figured that the inverter eats up some battery pretty good - the amount I had to use it did not make a big difference as I boondock at this point only for shorter trips
Old 10-14-2014, 09:12 PM   #50
rp709's Avatar
2015 30' Flying Cloud
Ventura , California
I now own a 2015 Flying Cloud 30 RB. The WFCO 1000 inverter has a built in transfer switch. I ran a flat plug extension cord from the nearby roadside outlet down behind the L- lounge cushion and through the removable wood panel above the inverter, and plugged it into the inverter power cord. I now have shore power to the blue label outlets or inverter power if on battery. It work well.
rp709 is offline   Reply With Quote
Old 10-15-2014, 07:01 AM   #51
lewster's Avatar
Naples, FL , Hood River, OR
So the question remains: why doesn't the factory install the WFCO inverter in the way it SHOULD be installed to allow the 120 VAC pass thru when on grid and eliminate the redundant outlets??
Better yet....... Why don't they use the Magnum MMS-1011 which also has a great 4-stage charger WITH temperature compensation like they do on the Interstate coach???? They already use the Magnums, so why not include them on their 'premium' trailers?????
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 10-15-2014, 07:10 AM   #52
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
I only use the factory inverter when running heavy loads. For charging laptops and such, I purchased a small portable 200w inverter. Works in the tow vehicle as well.
SCOTTinNJ is offline   Reply With Quote
Old 10-15-2014, 07:11 AM   #53
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Speaking of the factory inverter, does anyone know what happens if it is overloaded? Is there a fuse that blows (and therefore needs to be replaced) or a circuit that trips?
Old 10-15-2014, 07:53 AM   #54
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Overnight cell phone battery charging with this will use I guess much less juice than running the inverter overnight?
Old 10-15-2014, 07:54 AM   #55
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Factory 1,000 watt inverter
I wish the inverter outlets could work for shore power OR for inverter (extra shore outlets would be nice
Or have the standard outlets double as both
Old 10-15-2014, 10:43 AM   #56
mefly2's Avatar
OK ...if and only if you have a place in which to plug it ... late model AS have eliminated the 12vdc power points and replaced with USB ...
600 Watt Inverter PWirtz Batteries, Univolts, Converters & Inverters 13 01-10-2015 12:01 PM
Generac iX 2000 Watt Portable Inverter Generator Frank&Mike Generators & Solar Power 21 11-06-2014 06:20 PM
5000 BTU/hr AC and 1,000 Watt Genny TouringDan Furnaces, Heaters, Fireplaces & Air Conditioning 36 08-01-2012 08:46 PM
Need options for 3000 watt inverter Dwight Batteries, Univolts, Converters & Inverters 1 08-30-2011 08:55 AM
Yamaha EF3000iSE 3,000 Watt DL46 Batteries, Univolts, Converters & Inverters 2 09-28-2010 03:16 PM
