10-16-2015, 08:36 AM
2011 23' FB Flying Cloud
Augusta
, Kansas
External battery disconnect switch
I have 2011 fc with a double battery in metal box (factory). To anyone who has installed a battery disconnect switch. Where did you mount the switch? Thank you.
10-16-2015, 08:54 AM
2015 25' International
Scottsdale
I mounted mine on the side at the upper right corner where the wires enter thee battery box.
2017 Ford F-250 Diesel
WBCCI # 5462 4CU
10-16-2015, 09:08 AM
2008 25' Classic
Full Time
I find it just too easy to disconnect the negative battery cable rather than going to the hassle of installing a battery disconnect switch.
Kelvin
2008 Classic 25fb "Silver Mistress"
2015 Ram 2500 6.7L Cummins. Crew Cab, 4x4, Silver
10-16-2015, 09:37 AM
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel
Isolation Switch Location
Best, Burnside
"To err is human, to air is devine."
10-16-2015, 09:39 AM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
Just a thought, but if you are going to go through the effort of installing a switch you may as well get one that can lock. Added level of theft prevention if the thief can't raise the jack easily.
@living.somewhere.yonder | Instagram
10-16-2015, 10:25 AM
Superior
If I install batteries inside the trailer, is there any reason I can't mount and use this switch inside? safety issue?
Thanks!
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
10-16-2015, 10:42 AM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
Thanks!
You can safely mount AGMs and LFP batteries inside the trailer and obviously the switch can be inside as well. Do not mount wet cell batteries inside the coach as they will off-gas and that is bad news. Some older Classic model Airstreams have wet cells mounted essentially inside the trailer and use some method to vent to the outside. Given the availability of safe AGM batteries nowadays, there is no longer any reason to try and place wet cells inside the trailer.
Bob Martel
WBCCI# 5766
10-16-2015, 10:58 AM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Best of both worlds here.
Short battery cable runs and the ability to cut it on or off from outside.
http://m.summitracing.com/parts/fla-fr1003-2
And more;
http://m.summitracing.com/search?key...y%20disconnect
Brevi tempore!
10-16-2015, 11:05 AM
1972 31' Sovereign
Benton
, Arkansas
Or a budget and very simple solution....
http://m.summitracing.com/parts/mor-74103
Brevi tempore!
10-17-2015, 12:50 PM
1973 31' Sovereign
Mt Angel
On my trailer the hitch jack is factory wired direct to the batteries so it will work regardless of battery disconnect switch position. To disable you can remove the fuse, or install a hidden in-line switch, or move the jack 'hot' wire to the disconnect switch output post.
With the disconnect switch in "off" everything inside the coach will be "off", eliminating the 'parasitic' drains like the propane detector.
A parasitic drain I have not seen mentioned elsewhere in these forums is the 'power on' indicator lamp in remote controlled Fantastic Fans.
Best, Burnside
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Battery Disconnect Switch Not Working
Toronto_Guy |
10 |
06-26-2020 02:35 PM |
Battery Disconnect Switch, Solar & AGMs
SilverGate |
32 |
08-26-2019 01:23 PM |
To disconnect or not to disconnect
urnmor |
Towing, Tow Vehicles & Hitches |
36 |
02-22-2017 10:24 AM |
Battery Disconnect Switch Question
MaryD |
4 |
07-13-2013 08:19 AM |
nsbcpa |
5 |
08-10-2012 05:11 PM |
