Old 10-16-2015, 08:36 AM   #1
2011 23' FB Flying Cloud
Augusta , Kansas
External battery disconnect switch
I have 2011 fc with a double battery in metal box (factory). To anyone who has installed a battery disconnect switch. Where did you mount the switch? Thank you.
submirj is offline   Reply With Quote
Old 10-16-2015, 08:54 AM   #2
Ponyfvr's Avatar
2015 25' International
Scottsdale , Arizona
I mounted mine on the side at the upper right corner where the wires enter thee battery box.
2017 Ford F-250 Diesel
WBCCI # 5462 4CU
Ponyfvr is offline   Reply With Quote
Old 10-16-2015, 09:08 AM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I find it just too easy to disconnect the negative battery cable rather than going to the hassle of installing a battery disconnect switch.
Kelvin
Old 10-16-2015, 09:37 AM   #4
Burnside Bob's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel , Oregon
Isolation Switch Location
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
Old 10-16-2015, 09:39 AM   #5
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Just a thought, but if you are going to go through the effort of installing a switch you may as well get one that can lock. Added level of theft prevention if the thief can't raise the jack easily.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 10-16-2015, 10:25 AM   #6
ericpeltier's Avatar
Superior , Colorado
If I install batteries inside the trailer, is there any reason I can't mount and use this switch inside? safety issue?
Thanks!
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 10-16-2015, 10:42 AM   #7
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Thanks!
You can safely mount AGMs and LFP batteries inside the trailer and obviously the switch can be inside as well. Do not mount wet cell batteries inside the coach as they will off-gas and that is bad news. Some older Classic model Airstreams have wet cells mounted essentially inside the trailer and use some method to vent to the outside. Given the availability of safe AGM batteries nowadays, there is no longer any reason to try and place wet cells inside the trailer.
Bob Martel
WBCCI# 5766
Old 10-16-2015, 10:58 AM   #8
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Best of both worlds here.
Short battery cable runs and the ability to cut it on or off from outside.
http://m.summitracing.com/parts/fla-fr1003-2
And more;
http://m.summitracing.com/search?key...y%20disconnect
Brevi tempore!
Old 10-16-2015, 11:05 AM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Or a budget and very simple solution....
http://m.summitracing.com/parts/mor-74103
Brevi tempore!
Old 10-17-2015, 12:50 PM   #10
1973 31' Sovereign
Mt Angel , Oregon
On my trailer the hitch jack is factory wired direct to the batteries so it will work regardless of battery disconnect switch position. To disable you can remove the fuse, or install a hidden in-line switch, or move the jack 'hot' wire to the disconnect switch output post.
With the disconnect switch in "off" everything inside the coach will be "off", eliminating the 'parasitic' drains like the propane detector.
A parasitic drain I have not seen mentioned elsewhere in these forums is the 'power on' indicator lamp in remote controlled Fantastic Fans.
Best, Burnside
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Battery Disconnect Switch Not Working Toronto_Guy Batteries, Univolts, Converters & Inverters 9 04-13-2015 05:39 PM
Battery Disconnect Switch Question MaryD Batteries, Univolts, Converters & Inverters 4 07-13-2013 08:19 AM
Battery Disconnect Switch nsbcpa Batteries, Univolts, Converters & Inverters 5 08-10-2012 05:11 PM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 29 11-03-2010 10:52 AM
