Old 05-07-2013, 08:05 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Exterior outlet discovery
Read about replacing the exterior AC outlet cover. Since our cover is warped I figured I would replace before it caused a problem.
Apparently this was providential to act first.
Lookie at what I found from PO's!
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-07-2013, 08:13 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Now, the 'outlet' is one of those 'crimp' connect deals where they have sharp metal parts that cut through the wire insulation to make contact. The plastic part that holds wires in place is cracked and so allowing water inside when it rains.. (rare in Texas, I know)... but this is a Travel Trailer!!
So, I figure I have to go to the Electrical Supply house, (No HoDep), and find a watertight box, one that will mount, somehow inside this opening...
The PO's managed to get the screws to wedge in, but once I pulled on the cover a bit, it started to pull away from the aluminum...
I don't know how the 'arc' hole happened, but can only presume PO and something to do with water...and electricity... but there is no 'known history' and this might have well occurred at JC!!
Advice/recommendations?
Old 05-07-2013, 08:39 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I think the unused original screw holes, new enormous mounting holes that fit the replacement fixture, and gouging out of the original opening are pretty good clues this was an aftermarket butcher job.
Don't you?
Try to find an outside receptacle that will cover that opening. Is there a ground wire present?
doug k
Old 05-07-2013, 08:42 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Don't you?
doug k
yessir!
I may have to do an overlay of Diamond Plate!
Old 05-07-2013, 10:36 PM   #5
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
the circuit supplying this outlet should be protected with a GFCI breaker. if not, install a new GFCI breaker in you subpanel, or,
replace the existing outlet with a suitable protective box, a GFCI outlet, and an appropriate external weather resistant cover.
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 05-08-2013, 06:24 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
best,
Thanks! Will do! Need proper electrical safety!
Channing
WBCCI# 30676
Old 05-08-2013, 06:54 AM   #7
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Would this work? We installed one on Little Girl. It replaced the old water fill.
Receptacle Housing for Exterior 120 Volt 500169 [500169] - $86.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Chris
