Old 02-03-2005, 02:55 PM   #1
mandolindave's Avatar
Extension cord to plug in trailer
I have been using an orange 16 gauge power cable to charge and
power my trailer while it sits in the driveway. I had no problems
until the snow came. Now the extention cables gets hot and trips
my house circuit breaker. Any ideas what went wrong or what to look for ????
mandolindave is offline   Reply With Quote
Old 02-03-2005, 03:56 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
green stuff on the ends!
corrosion on the connections increases the resistance in the circuit and causes the heat and the breaker tripping.
toss it out and get or make a good cord out of type SO cord.
john
you call them ferrets, i call them weasels.
Old 02-03-2005, 05:43 PM   #3
1971 29' Ambassador
Leonardtown , Maryland
16 gauge cable
16 gauge is a little too small. I would go to a 14 or even a 12 gauge to take power to the trailer.
Any cable that gets hot when in use is over loaded and a potential fire hazord.
Good luck
dale
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 02-03-2005, 06:13 PM   #4
Extension cords, even 25 feet, should be a minimum of 10 gauge.
50 feet should be 8 gauge.
Old 02-03-2005, 07:03 PM   #5
Images: 59
Dave,
I think what happened is your battery charger went from 'float' to 'charge', and it by chance coincided with the first snowfall.
The higher amp draw was more than a 16 ga extension cord could handle.
Old 02-03-2005, 07:44 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Get the shortest extension cord you can use, the shorter it is, the better off you are (less voltage drop).
There is a formula for length of extension cord to amp draw, I have forgotten the specifics. If your trailer is 15' from the outlet, get a 16 foot cord, if possible, and make it a 12 gauge or heavier. I have a 25 foot 10 gauge extension cord, and I wish it were a little heavier.
Old 02-04-2005, 07:09 AM   #7
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
A hidden source of problems is broken tiny copper filaments, especially at the point where the cable enters the connector. This area gets a lot of twisting during use. If you keep the green crud polished off the connector and it still gets warm, snip off the last 4 inches of cable and install a new connector.
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 02-04-2005, 07:15 AM   #8
Thanks, but I still wonder......
if the snow insulated the wire or something. It has been fine for 2 years
without the circuit breaker tripping. Maybe my batts were always
charged from the trip home.( I had the trailer unhooked for a month)
Old 02-04-2005, 07:32 AM   #9
LOST , Hawaii
http://www.csgnetwork.com/wiresizeca...&amps=4&wire=0
Url for a wire size calculator (can't get the hyper link to work). There are some other calculators there too.
John
74Argosy24MH is offline   Reply With Quote
Old 02-05-2005, 08:30 AM   #10
Nye Thatcher's Avatar
If you are using an outside receptical on your house it should be on a G.F.I. circuit braker which trips when it senses the least amount of moisture. I would use a heavier cable and moisture proof connections.
Nye
Nye Thatcher is offline   Reply With Quote
Old 02-05-2005, 05:36 PM   #11
Well Preserved
1993 21' Sovereign
John
Thanks, John. That was the one I was thinking of.
What ever happened....??? gwsullivan Our Community 2 02-13-2003 04:11 PM
No water to toilet Oak Sinks, Showers & Toilets 13 11-01-2002 06:31 AM
Rotors for vacuum disk brakes wvmiller Brakes & Brake Controllers 4 10-21-2002 04:43 PM
moved and tore loose what happened overlander General Interior Topics 5 09-24-2002 06:50 PM
12V trouble.... Chuck Electrical - Systems, Generators, Batteries & Solar 8 07-06-2002 04:57 AM
