Old 05-11-2015, 01:46 PM   #15
dznf0g's Avatar
Oswego , Illinois
Oh, yeah, Kelvin...I remember that thread now. I don't know if the Dexter has a keep alive circuit or not...I would assume so.
-Rich-
Old 05-11-2015, 01:57 PM   #16
SteveH's Avatar
Common Sense , Texas
My Dexter actuator is connected to the battery as well as the brake signal from the truck. Basically it uses the battery for power, and the brake signal from the controller as the signal.
Regards,
Steve
low voltage cutoff vs AMP hours used at high amp draw morgandc Batteries, Univolts, Converters & Inverters 0 11-02-2014 09:38 PM
1960 Brass Dump Valve ~ Not What I Expected Sugarfoot Waste Systems, Tanks & Totes 12 09-09-2008 09:53 PM
Delivery date: Sooner than expected hampstead38 1967 Overlander 17 08-14-2008 08:18 PM
Temperature Differential Expected JimGolden Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-28-2005 10:48 AM
Not the bearing I expected Miller Axles 0 07-19-2005 06:21 AM
