This electrical stuff is really confusing for a newbie.
We are taking delivery of a new 08 Safari SE 27FB next week and want some advice on what if any upgrades we might have the dealer do before we take delivery.
We'll boondock for a few days at a time and plan on getting one Honda 2000 to start and perhaps a second one in parallel later.
The unit has the audio / tv upgrade. 2 fantastic fans. We'll probably mostly use lights and such. And a laptop. We are coffee drinkers and will want to run a coffee machine every morning.
I've received advice to upgrade to a 3 stage converter as one example. I'm uncertain what the relative importance of doing so is over what comes standard on the unit. Also, not certain about the battery meter that comes with the unit and whether that is sufficient.
Solar is another thought. But it seems the generator will really be needed to run anything with a significant draw anyway so is that really useful?
We want to take advantage of doing any of this stuff predelivery since it will avoid service visits later!
Advice from all you experienced folks on any and all electric please!!! Thanks.
Hector and Brenda
"Luna" - 08 Safari SE 27FB
08 Toyota Tundra
First off, a big Forums welcome to you. You're gonna love Airstreaming, and a 27FB is a great floor plan.
We have an '05 25FB, named Lucy, that we have spent over 200 nights in and absolutely love her. You've already got the only thing that we added later, and that is a second Fantastic Fan in the bedroom. We have not added any other upgrades to Lucy, herself.
We did add a Hensley which has performed as advertised for almost 30,000 miles of towing. We also have a pair of the Honda EU2000i's. These are great generators.
Best of luck with your new baby and safe travels,
Brian
__________________ SuEllyn & Brian McCabe WBCCI #3628 --- AIR #14872 2005 25' Safari FB (Lucy) with HAHA 2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
The honda will run most everything. It may run the AC if nothing else is used.
Comfy options. They do make 12V Coffee makers.
the factory converter works ok.
the battery meter that come with the factory installed solar option is better than the standard one.
solar is good for topping off the batteries. When I travel cross country the solar panels andthe truck will bring the batteries back up or hold them if I run the heater while travelling.
Hector and Brenda
08 Toyota Tundra
Good plan.
Michelle
Think you are having a bad day? Go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar) http://Michelles-Adventures.US
The main reason for getting a 3-stage battery charge is to properly charge your batteries, which will in turn extend their service life. The stock converter puts out a uniform charging voltage of 13.8 volts, which is too low to properly charge your batteries (14.4 volts) completely and too high to maintain them (13.2 volts).
Extended use will eventually boil the fluid from your batteries, causing premature failure. With a 3-stage charger, you can just forget about the entire charging process and know that your batteries are properly taken care of!
PS: A single Honda 2000 will not run your A/C, but a pair definitely will! A Yamaha 2400 WILL run your A/C.....up to 13,500 BTU. (according to the Yamaha web site)
Solar vs Generator(s) - it's a belt and suspenders thing.... do you need both? A lot depends on your style of camping. Solar works better in non-shaded camping spots, so a backup generator is a good idea. On the other hand if you have generators, why bother with solar? A generator will recharge the battery at 4 am if you don't have neighbors who'd complain. Solar is great for maintaining your batteries, and running lights.
Appliances like a microwave, coffee maker and crock pot. RETHINK - boil water on your stove top using propane, then French Press it. I just got a Dutch Oven - campfire model - and made cobbler as my first experiment. There's the predecessor to the crock pot, and it makes the yummiest stuff - the neighbors were drooling. If you give up your microwave for a month, you may never want it back. REAL cooking just tastes that much better. I've gotten used to using a campfire/stovetop toaster too.
SPACE is your really big consideration. You're going camping to get away from it all, not haul it all along with you.
Get what suits you - but realize that you'll be heavily tempted to buy way too much stuff that you will seldom if ever use! I have one wire wisk, 4 really good sharp knives and a set of kitchen utinsels including an egg beater and a soup ladle that I've rarely used in almost four years. Last time I made soup, I used a coffee cup to ladle it out because I couldn't remember where the hell I stashed the ladle. Worked FINE. The ladle is going to the kitchen at work when I find it. (That set of nesting pots from Camping World IS worth it's weight in gold though.)
Paula
Today is a gift. That's why they call it "the present"
Congrats on the new addition to your family! You have a wonderful AS and will have many great nights/days enjoying our beautiful country. It seems that you have all of the important bases covered (2 fans-good choice). I agree with Lewster about the 3-stage charger....this is a must for dry camping if you want the most efficiency from your battery power (you don't say how many, but 2 batteries is a good thing). You may want to spend a few days camping before any major changes.
I use the Yamaha 2400 and it runs the AC without a problem, and no need to deal with 2 generators. It is very quiet and has been a flawless unit.
Again, Congrats on your new purchase and Happy Camping!
Lewster,
If the converter put in by the factory is so inferior why do they use it??? If I should switch mine what brand/model do you suggest and how much is it to switch?
__________________ Brian & Donna 08 27' Safari FB SE 03 Avalanche 2500 WBCCI #1199 - AIR #23847 NEU LIFE IS GOOD
The factory-supplied converter is suitable for occasional use. Occasional being the one weekend or so per month most RVers use their coaches.
If you are going to use your coach more, or leave it plugged in at home constantly, it makes sense to upgrade to e 3 stage converter. They are not all that expensive.
If you don't leave it plugged in at home what do you do? Leave it plugged in intermittently?
Yes, kind of like the Army Reserves--one weekend a month, and two weeks a year.
If you are going to leave the fridge on all the time, it would make sense to, among other things, upgrade to the 3 stage unit.
We have a 2005 A/S. I leave it plugged in at all times, whether camping, or at home in the shed. The batteries need water once every 4-6 months. Our 1970 model would cook the batteries promptly, but this one is very gentle. Yes, perhaps it doesn't put a GOOD charge into them. I think the Tow vehicle does that.
So far, we have not needed a gen set for our camping. At present, I would go for a Honda 1000 to maintain charge, or the Yamaha 2400 sounds like a good size for heavier use.
Lewster,
I'm sure that you can blame the suits at Airstream for that decision..... strictly economics!!
