09-30-2010, 02:43 PM
1986 25' Sovereign
Plant City
Electrical system upgrade
So after owning the stream for a little over 6 months I have come to realize that the amount of information that the trailer provides about battery status, solor charge amount, and voltage is very lacking.
Currently the trailer has a system installed by solarmetrics(no longer in business). In this system I have a xantrex solar charger, xantrex 25kw inverter, 3 solar panels, 3 flood cell batteries, and one univolt that will be my newest boat anchor.
I think that the solar charger and the inverter support the network information via a telephone cable. My question is, "is there a system with a charger and a control panel/information system that i can install?"
Thanks in advance,
Chris
PS: the more information the better
09-30-2010, 03:30 PM
1974 Argosy 26
Morrill
, Nebraska
25 KW Inverter? There must not be any living space with an inverter that large. I'm think you ment 2500 watts. Didn't you?
09-30-2010, 04:03 PM
Wise Elder
2010 30' Classic
South of the river
Most of the Xantrex inverters also have a charger feature, which if wired up, would work better than the Univolt.
Depending on the inverter model you should be able to get a control panel for it, see bestconverter.com. But, you may find that aftermarket charge monitors and shunts are a better answer in your situation. There are several makers, I know Xantrex makes one, and Randy at Bestconverter sells a different one, and the marine guys seem to use yet a third one.
09-30-2010, 06:19 PM
Sioux Falls
, South Dakota
What's a shunt?
Gary
09-30-2010, 08:23 PM
Wise Elder
2010 30' Classic
South of the river
A device for redirecting a small percentage of the current going through a wire to meter so that it's easy to measure the amps. The charge monitors that show an accurate % of how much battery is left do it by measuring the amps being drawn or charged all the time so they can subtract and figure out how much capacity is left.
09-30-2010, 08:43 PM
Sioux Falls
, South Dakota
Thanks! Now, charge monitors for dummies: In practice, how is the after-market charge monitor installed in a travel trailer like mine with one battery installed? Is there a two wire lead connected to the battery? Interesting topic.
Gary
09-30-2010, 09:08 PM
Wise Elder
2010 30' Classic
South of the river
I have never put one in but I believe they're typically six wires, power and ground, two to the shunt, and two for voltage sense that go straight to the + and - terminals.
09-30-2010, 09:14 PM
Sioux Falls
, South Dakota
Interesting, Thanks!
Gary
10-01-2010, 06:24 AM
1978 31' Sovereign
Texas Airstream Harbor
, Zavalla, in the Deep East Texas Piney Woods on Lake Sam Rayburn
Here is an amp minder installation - separate charge system
Originally Posted by ck21084
... "is there a system with a charger and a control panel/information system that i can install?"...
...the more information the better
Here is a typical installation of a Tri-metric 2020 Ampminder - the display head is installed in the overhead adjacent to the stove vent control. My memory is a bit fuzzy, but I think there were only 4 wires (two twisted pairs) that needed to be hooked up - all wiring was included in the installation kit.
Not sure if this is the best system for a Solar installation - best to do a through study if you are really serious about staying off the grid for extended times.
Below is a shot of the measuring shunt installed on the negative side of the battery - the shunt sensing wires were not yet installed when the picture was taken.
The Tri-metric website can be found here:
TriMetric Battery System | Bogart Engineering
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
10-01-2010, 07:15 AM
1986 25' Sovereign
Plant City
I agree with you that it is a 2500w inverter... but for some strange reason it says "25kw" on the front of it. LOL
Maybe thats a marketing thing.
12-01-2010, 09:39 AM
1986 25' Sovereign
Plant City
Update: After much research the inverter that I have does not have the charge feature installed. This being said I have decieded to go with a xantrex 60 amp charger. This will allow for seperate charging of the bateries and there is a special on them right now where you get the control panel and remote temp sensor for free with the 20,40, and 60 amp unit. Best converter did not have this deal so I decided to order from another retailer. I paid $430 for this unit.
I now have to figure out how to link the two batteries together since they are being charged seperatly and i also need to figure out what wire size I will need. I currently have 1/0 awg welding cable. During this process i will also change out the terminal blocks that are exposed for some that have protective covers like used in car audio. These will often support 1/0 or larger. I have also been pondering the idea of installing a 5 farad capacitor. Do you think I would see any benifit from this? I have one in my car and it started my car when the battery was very weak.
Thanks to all for the info
12-01-2010, 10:18 AM
1986 25' Sovereign
Plant City
Here is a quick diagram.
Thoughts?
12-01-2010, 11:33 AM
1958 26' Overlander
Mesa
Hi Chris,
I installed a Xantrex Freedom 10 (1000w) Inverter/Charger along with a Xantrex Link 1000 remote control/display unit. The inverter is wired to all of my 110v A/C outlets which is great (my 12v system has two 12v Size 27 batteries). I'm in the process of installing two 95watt Sunwize solar panels with a Xantrex C35 Charge Controller. Several pics of this installation (except for Solar) can be found in my blog.
Good luck.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
12-01-2010, 02:44 PM
1986 25' Sovereign
Plant City
Originally Posted by mello mike
Hi Chris,
Good luck.
Mike,
Thanks for the info. I looked at your blog and will be using some of your info. I already have the solar and inverter in place. I will be removing the univolt for the upgraded Xantrex 60 amp but want to change the wiring around.
Chris
12-02-2010, 06:21 AM
1986 25' Sovereign
Plant City
TTT
Wait this is post 100 for me.
12-04-2010, 09:47 AM
1986 25' Sovereign
Plant City
Any one have any sort of feed back on my idea? I am receiving my charger on Monday and have purchased 6ft of 1/0 power cable and 12ft of 4ga power cable. As well as the distribution blocks.
Chris
12-04-2010, 10:11 AM
More than one rivet loose
Los Alamos
, New Mexico
Usually four wires. One big one in, one big one out. Two little ones to the amp meter.
Michelle TAC MT-0
Sarah, Snowball
