I know for a fact that I plugged a 2006 safari into a 240 Volt outlet. The capacitor (C7 on the circuit board) near the fuse box and converter completely blew out and nearly started a fire.
The plug has since been replaced with a 120 Volt outlet, but only a few systems work.
The good: Lights, Battery Charging System still work.
The bad: Fridge is on Gas, GFCI bath-Refer-Gallery(?) breaker breaks every time you attempt to turn on, & Microwave won't work.
What else is needed besides a new capacitor, converter? Who or what is a good source to fix this?
I would start by unplugging the appliances from the circuit if possible then testing the circuit(s) for damage without any load, then add each appliance until you isolate the cause. You might find damaged wiring, but if other circuits are ok, it more than likely is some type of appliance or power drawing item on that circuit that is fused between both poles and tripping the breaker.
roof locker tracks (plastic) square cornered astrodome screen 63 refer, or at least the original door insert 2 12v hehr motors (working) w/ or w/o fan blade
The Fridge is probably toast... (the circuit board in it anyway). I did that about 5 years ago (the electrician was to put in an outside 30A 120 plug and he wired it for 240v.... his insurance covered all my damage. If you have an electronic ignition water heater, check that too. Good luck.
Rob, Zoe', Stanton, Bryce and Braedon Baker
Past President WDCU
Do you Listen to the www.theVAP.com
Plymouth, NY 13832 WBCCI #2820
Some portable electronic items are set up to handle dual voltages. Things like laptops, cell phones and most things with a "Charger" work fine, but built-in items generally don't.
If it were me:
I would suspect that the damage is at the appliance(s) and not the wiring. I would confirm this by checking the trailer circuits first as goransons recommended. If the voltages check out ok at the wall plug then I would start on the individual appliances.
Is the gfci tripping without something being plugged in?
You're not the first, or the last person to have this happen. It's easy to mistake the NEMA TT-30 plug for 240 volts.
Regards,
Kevin
__________________ Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
Michael
Michael,
It is quite possible that the breakers are toasted as well. they are rated for 120 VAC 30A,15A,15A... with 240 you halved the current but the magnetic trip system in the breakers may have been damaged.
As for your items that do not work. all the control boards are likely fried.
the heater coil on the fridge may be damaged as well if it was on electric.
The AC wire (insulation) is rated up to 600 volts.
Your best bet is to take back to the dealer and have the do a once or twice over.
