Old 06-18-2018, 02:00 PM   #1
2014 19' Flying Cloud
Selinsgrove , Pennsylvania
Electrical service box
Help! Our electrical service box under our closet has rattled partway out due to the crappie roads. Any advice on how to fix? We have a 2014 19 foot flying cloud.
Thanks!
Mb
wmbechtel is offline   Reply With Quote
Old 06-18-2018, 02:51 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
I'm assuming you are talking about the load center (and that it's similar to mine). It normally hooks in via a couple of screws into the edges of the plywood.
The gotcha in playing with it is that you have both 12V and 120V in the box. Disconnecting the 120V is pretty easy ( don't plug into shore power ). The 12V involves lifting (= disconnecting ) the negative wire to the battery.
Once you have the power off, *gently* try to work it back into place. You very much do *not* want to pinch any wires as you get it back in there. Assuming it slides back in ok, you then just have to re-attach it to the cabinet frame.
How you attach it depends a bit on how it parted company with the frame. Best guess is that the screws stripped out. They also could have broken. It's possible the wood actually broke. Each issue would require a slightly different solution. There are to may variables there to randomly toss up ideas without more information.
So - how did it break free ( = what separated as it came loose ) ?
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box 59as Airstream Classifieds 0 09-19-2014 11:01 AM
Cracker box after cracker box. rebel beck Our Community 15 06-07-2006 07:53 PM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
