Old 06-12-2009, 08:53 AM   #1
1974 27' Overlander
youngstown , Alberta
electrical problems UNIVOLT???
my 1974 overlander 27ft
there is no 110, no 12v, univolt is humming...
last time i tried to flick on/off breakers, and it worked all of it then the univolt is humming but no power...
the 110 plug at both ends is hot from shore power????anyone have this problem?
Thanks liz
YOUNGSTOWN, A SMALL DRINKING TOWN WITH A FISHING PROBLEM.......ELIZABETH
tinlizzie2 is offline   Reply With Quote
Old 06-12-2009, 09:41 AM   #2
SteveH's Avatar
Common Sense , Texas
It sounds like you may have several problems. If the univolt is "humming", it is getting 110 AC, so your AC problems are in the trailer. Most likely a braker. If you also have no DC (12 volts), you may have problems with a fuse (there are a couple in the main 12 VDC line), or there may be problems on the 12 Volt fuse and connector board. In either event, you will probably need a volt meter to find the problem for sure.
Old 06-13-2009, 08:54 AM   #3
1974 27' Overlander
thanks Steve
found main fuse on ground side out of univolt blown everything came back and is working right....
Electrical Problems? Paul Dobbin Land Yacht/Legacy Motorhomes 3 12-11-2007 07:04 PM
Electrical / Univolt question pamelake Electrical - Systems, Generators, Batteries & Solar 4 01-15-2007 05:29 PM
'78 Argosy Electrical Problems - Univolt? joshw Argosy Motorhomes 3 11-06-2006 03:43 AM
'69 Soverign Univolt Problems? rock Batteries, Univolts, Converters & Inverters 11 08-23-2005 06:02 PM
Electrical Problems Bob Baker Electrical - Systems, Generators, Batteries & Solar 4 06-20-2003 11:31 PM
