Old 08-24-2008, 11:21 AM   #1
I BEgan's Avatar
Ogden , Utah
Question Electrical Mystery
While on a road trip to the Oregon Coast last week, my univolt abused battery finally gave up the ghost. I had been limping along with it's poor performance and relying on either my generator or shore power and primarily used the battery only while operating the jack. When even this was too much, I figured it was time and picked up a new Exide Nautillus Gold (675 mca, 182 min reserve, 550 cca, 182 rc, 105 amp/hr). To hear my water pump hum along without shore power was very foreign to me.
The next morning, my wife was getting ready while I got our gear together and unhooked our campground connections. Seconds after running off of the battery, the water pump kicked on and blew the main 40 amp fuse. I think she had a few lights on besides the pump. I changed the fuse, tested it and off we went.
Similar situation the following morning only this time when the power kicked off, the fuse was OK and I cannot figure out why. Everything functions normally while connected to shore power. The battery is fully charged and producing around 13 V. I am getting the same voltage at the fuse box. All fuses have been tested as good. When I attempt to turn on the compact florescent ceiling lights they blink as if they are getting a spike of juice.
I am running an 60 amp Intellipower with Charge wizard.
Any info is greatly appreciated. I have a multi-meter but only know enough to be perplexed.
Brandon
Whenever you find yourself on the side of the majority, it is time to pause and reflect.
-Mark Twain
I BEgan is offline   Reply With Quote
Old 08-24-2008, 02:44 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
I'd vote for a loose connection somewhere around the battery cables.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 08-24-2008, 04:41 PM   #3
mustang's Avatar
1999 27' Safari
Kent , Ohio
I wonder if your pressure regulator on the water pump is set to high, and when your hooked to shore power you have the extra oomph to hit what your regulator is set at but on the battery power you never acheive this so the pump is on pushing hard (seeing spikes in the lighting) as it cycles until the fuse pops because it over heats. low amperes high volts will cause that scinerio, My weak battery (9 years old or so) causes the lights to flicker when pump is at the high end of pressure setting. Just my thought. good luck I am intrested in the cause. Is the battery to small? do a load test also. I am not sold on exide or interstate. they used to be a good battery, but I have seen recent issues. I chose NAPA or New Castle and heard good things about A/C voyager.
mustang is offline   Reply With Quote
Old 08-24-2008, 06:50 PM   #4
I BEgan's Avatar
Ogden , Utah
I checked the cable connections right away, so I can rule that out.
I am wondering about where the negative cable from the battery gets grounded. I'm thinking a bad ground could be the culprit.
I am interested in the water pressure theory. I did mess around with the pressure regulator a couple of days ago to compensate for extreme pressure at a campsite. At the time, I thought this would only affect the water coming from the fresh water inlet (hose). Is there a regulator off of the water pump or is the pressure regulator where the water comes into the trailer one and the same? BTW, I am still running the original water pump.
-Mark Twain
Old 08-24-2008, 07:00 PM   #5
Excella CM's Avatar
Venice , California
You need to check the high pressure limit switch on the pump itself. The pressure regulator for city water is not electrical.
Old 08-24-2008, 08:01 PM   #6
I BEgan's Avatar
Ogden , Utah
Will do. This still doesn't get me up and running though. Again, even though all of my fuses checked out through resistance tests, nothing works while being powered only through the battery.
Any ideas?
-Mark Twain
Old 08-24-2008, 08:55 PM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you find a source for 40 amp AGC fuses (the size for car fuse boxes, about 1 1/4"x 1/4" ) at a regular price let us know. I have tried auto parts and audio with no luck. The highest I can find is a 35. I am now using a auto reset breaker.
Old 08-24-2008, 09:15 PM   #8
I BEgan's Avatar
Ogden , Utah
I picked up half a dozen yesterday at my local RV store. Worst case scenario, you could buy them there www.statetrailer.com I am certain I have found them at Autozone before as well, though.
-Mark Twain
Old 08-24-2008, 09:54 PM   #9
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
Here's a source...
I found them here pretty cheap:
http://www.terminalresolutions.com/s...GC-Fuse/Detail
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 08-25-2008, 06:08 PM   #10
I BEgan's Avatar
Ogden , Utah
Anyone have a wiring diagram for a 74 Sovereign?
Thanks in advance!
-Mark Twain
Old 08-25-2008, 06:12 PM   #11
mustang's Avatar
1999 27' Safari
Kent , Ohio
I didnt catch your battery age, but a weak battery could cause the pump not to be able to acheive regulator pressure. Regulator on the pump, not city water into trailer You have a high limit and a lowturn on.
Old 08-25-2008, 06:15 PM   #12
mustang's Avatar
1999 27' Safari
Kent , Ohio
I see battery is new adj regulator on pump ( high limit) turn it down a touch
Old 08-25-2008, 06:35 PM   #13
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin , 28734
The onboard pump bypasses the regulator only city water is regulated. If you blew a 40 amp fuse it is most likely a short to ground. I would start by taking the fuse out that feeds the compact ceiling lights. If you take one fuse at a time out untill the problem gose away you can narrow it down.
Ramp is offline   Reply With Quote
Old 08-27-2008, 09:05 PM   #14
I BEgan's Avatar
Ogden , Utah
Could you elaborate for a multi-meter rookie?
I think you are correct about the short to ground. Again, I am reading 12.9V after the fuses, so it must be the ground, right? How do I trace this? Again, I have zero function of anything unless I am on shore power. I have figured out that the "spiking" of the compact ceiling lights was probably residual power from the inverter as it doesn't work after a while.
-Mark Twain
Old 09-06-2008, 10:31 PM   #15
I BEgan's Avatar
Ogden , Utah
Lightbulb Most problems seem simple in retrospect
Just to wrap up this thread, it turned out that I had mistakenly replaced the ground fuse with a 40 amp replacement used for the battery & tow vehicle instead of the 50 amp needed.
Thanks for everyone's input!
B
-Mark Twain
Old 09-07-2008, 06:49 AM   #16
We have the larger size univolt fuses rated at 40 and 50 amp. We also have the MDM 40 fuses as well.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-07-2008, 09:33 AM   #17
1969 29' Ambassador
orange Park , Florida
electrical mystery
I had the same problem with my 69 as everything would work while plugged in to shore power but with the battery nothing would work. I found the ground side from the battery had a blown 40 amp fuse. Changed the fuse and all worked again. On my 69 both the pos and the neg side has 40 amp fuses in the fuse panel. I have since taken out the original type fuse panel and went to an audio install shop and bought maxi fuse type holders so the fuses are more easy tio come by.
69AmbassFl is offline   Reply With Quote
Old 09-07-2008, 09:39 AM   #18
1969 29' Ambassador
electrical mystery
oops that was a pic of the old, here is the new
Old 09-07-2008, 09:46 AM   #19
Ottawa , ON
Glad to hear it was simple to fix, once you found what the fault was.
Can you solve this mystery? TitusLivy General Repair Forum 20 08-24-2008 10:18 PM
Mystery Part davida Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-16-2006 11:04 PM
Mystery Dents MattM Ribs, Skins & Rivets 11 07-15-2005 01:28 PM
Mystery MH PeterH-350LE Airstream Motorhome Forums 4 01-01-2005 05:57 PM
mystery parts Janet H General Interior Topics 7 11-18-2003 06:56 PM
