Old 09-06-2008, 10:31 PM   #15
I BEgan's Avatar
Ogden , Utah
Lightbulb Most problems seem simple in retrospect
Just to wrap up this thread, it turned out that I had mistakenly replaced the ground fuse with a 40 amp replacement used for the battery & tow vehicle instead of the 50 amp needed.
Thanks for everyone's input!
B
Whenever you find yourself on the side of the majority, it is time to pause and reflect.
-Mark Twain
I BEgan is offline   Reply With Quote
Old 09-07-2008, 06:49 AM   #16
Originally Posted by Lumatic View Post
If you find a source for 40 amp AGC fuses (the size for car fuse boxes, about 1 1/4"x 1/4" ) at a regular price let us know. I have tried auto parts and audio with no luck. The highest I can find is a 35. I am now using a auto reset breaker.
We have the larger size univolt fuses rated at 40 and 50 amp. We also have the MDM 40 fuses as well.
Old 09-07-2008, 09:33 AM   #17
1969 29' Ambassador
orange Park , Florida
electrical mystery
I had the same problem with my 69 as everything would work while plugged in to shore power but with the battery nothing would work. I found the ground side from the battery had a blown 40 amp fuse. Changed the fuse and all worked again. On my 69 both the pos and the neg side has 40 amp fuses in the fuse panel. I have since taken out the original type fuse panel and went to an audio install shop and bought maxi fuse type holders so the fuses are more easy tio come by.
69AmbassFl is offline   Reply With Quote
Old 09-07-2008, 09:39 AM   #18
1969 29' Ambassador
electrical mystery
oops that was a pic of the old, here is the new
Old 09-07-2008, 09:46 AM   #19
Ottawa , ON
Glad to hear it was simple to fix, once you found what the fault was.
Can you solve this mystery? TitusLivy General Repair Forum 20 08-24-2008 10:18 PM
Mystery Part davida Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-16-2006 11:04 PM
Mystery Dents MattM Ribs, Skins & Rivets 11 07-15-2005 01:28 PM
Mystery MH PeterH-Airstreamer Airstream Motorhome Forums 4 01-01-2005 05:57 PM
mystery parts Janet H General Interior Topics 7 11-18-2003 06:56 PM
